Tool Menu does not wait in Sculpt mode unless the cursor is hovering on the previously selected tool. #77085
11 Participants
Reference: blender/blender#77085
Operating system: Windows 10
Graphics card:
Broken: 2.90.3 alpha Date: 2020-05-25 19:50 Hash :
5254ffa17b
Branch: masterShort description of error
Tools menu does not wait even for a second Shift + Spacebar in Sculpt mode. Tricky thing is : unless the mouse cursor is on the previously selected tool in the menu.
Only when you PRESS TWICE the "Shift Spacebar" key combination TOOL MENU STAYS. i.e., Only if cursor hovering on the previously selected tool menu stays otherwise it disappears.
Added subscriber: @Shanthi
#84787 was marked as duplicate of this issue
Added subscriber: @mano-wii
Added subscriber: @lichtwerk
Looks like this will happen when the Toolbar popup gets pushed around (because it would not fit on the screen otherwise).
So when the
Draw
brush is selected (first one in the list) and you fire up Toolbar popup with your mouse way up on the screen it actually works/stays [menu opens with theDraw
brush under the mouse cursor, no change in tool, it stays].But if the
Draw
brush is selected (first one in the list) and you fire up Toolbar popup with your mouse way down on the screen it pushes the menu up [Draw
brush is not under the mouse cursor anymore, indicated change in tool, it switches the tool immediately and closes]Its not about pushing the menu up or down. Only If you can hold shift space and make the mouse cursor hover over the previously selected tool, Only then the Menu stays otherwise not. It does not let you select in the first place. It slows down the workflow if one can't switch between the tools smoothly. When menu is activated in the viewport itself the problem persist. There is no time for you to select the tool from the menu. If you want to select different tool Press Shift Space twice consecutively, only then the tool menu waits for your selection. When you press Shift space twice these two steps happen
There are even shortcuts for the tools in the sculpt mode, which are combinations of shift space. Which doesnot work.
Added subscriber: @ChuckOcheret
Added subscriber: @rjg
Since this issues hasn't been addressed, this also affects Blender 2.92 and 2.93 at the moment.
Added subscriber: @Rockbard
I can confirm this annoying bug.
It depends on the area of the mouse cursor occupying while you evoking the menu. If the mouse cursor happens to be on top of the unselected tool, this tool getting selected immediately.
I suggest removing the "fast selection" feature and let the shift + space menu stay until you have selected anything or moved away the cursor from the menu area.
Added subscriber: @aperitero-2
Added subscriber: @linxi
still happens in 3.0 and 3.1
Added subscriber: @NikolaKovac
I can confirm this bug in 3.0 too.
Added subscriber: @aoates
Added subscriber: @rmembrives
