Passing Dependency Graph to Drivers #77086
8 Participants
Reference: blender/blender#77086
Problem Description
Driver functions written in Python have access to neither the context nor the dependency graph that is evaluating the driver. As a result, it is not possible to reliably obtain the current view layer. Accessing
bpy.context.view_layer
is not a valid option here (see #75553), as there could be multiple view layers being evaluated at once (one rendering and one being shown in the viewport, for example).Proposed Solution
I think that conceptually the nicest solution for this is to make the currently evaluating depsgraph available to drivers. This can be done by passing it in the same way as we pass other driver variables, in
BPY_driver_exec()
. The driver "namespace" is not directly suitable for this, as it is a global object and thus has the same issues as accessingbpy.context
.To make
BPY_driver_exec()
aware of the current depsgraph, I see a few possible approaches:Depsgraph *
as parameter all the way down to theBPY_driver_exec()
call. This is conceptually the simplest solution, but it does require changing a lot of functions (see the call tree below). This approach can be broken down into:Depsgraph *
parameter to each function.float time
parameters with aDepsgraph *
, and use the depsgraph to obtain the time. This looks nice, but the evaluation time of the depsgraph and of the animation system can be different (for example when using the 'Animated Strip Time' of an NLA strip).Depsgraph *
and thefloat time
into a new struct, and pass that instead of thetime
parameter.Depsgraph *
. This avoids making changes to a lot of functions. However, given that people have worked hard to remove as muchG.main
from Blender's codebase, I don't think adding new globals is the way forward. Furthermore, this would require very careful consideration when creating and destroying dependency graphs.Depsgraph *
stored in a member variable rather than passed to each function.Call tree of
BPY_driver_exec
The
BPY_driver_exec()
function is called byevaluate_driver_python()
, etc. Every indentation level means "is called by". Functions are only listed once.BPY_driver_exec(time)
evaluate_driver_python(time)
evaluate_driver(time)
evaluate_fcurve_driver(time)
calculate_fcurve(time)
animsys_evaluate_fcurves(time)
animsys_evaluate_action_ex(time)
animsys_evaluate_action(time)
BKE_animsys_evaluate_animdata(time)
what_does_obaction(time)
actcon_get_tarmat(depsgraph)
BKE_animsys_evaluate_all_animation(depsgraph)
BKE_animsys_eval_animdata(depsgraph)
nlastrip_evaluate_controls(time)
nlastrips_ctime_get_strip(time)
nlastrip_evaluate_meta()
with time = strip-dependentnlastrip_evaluate()
nlastrip_evaluate_transition()
animsys_evaluate_nla(time)
animsys_calculate_nla(time)
BKE_animsys_get_nla_keyframing_context(time)
achannel_setting_slider_cb(context)
achannel_setting_slider_shapekey_cb(context)
insert_keyframe(time)
insert_key_button_exec(context)
ED_autokeyframe_property(context)
insert_action_keys(bAnimContext)
insert_graph_keys(bAnimContext)
autokeyframe_object(bAnimContext)
autokeyframe_pose(bAnimContext)
pyrna_struct_keyframe_insert(NOTHING)
(no context available)animsys_evaluate_drivers(time)
animsys_evaluate_action_group(time)
poselib_apply_pose(time)
poselib_preview_apply(context)
BKE_animsys_eval_driver(depsgraph)
fcurve_is_changed(time)
ui_but_anim_flag(time)
UI_context_update_anim_flag(context)
UI_block_end_ex(context)
insert_keyframe_value(time)
insert_keyframe_direct(time)
insert_keyframe_fcurve_value(time)
bAnimContext
objects are created byANIM_animdata_get_context(context)
, so they could be extended with aDepsgraph *
from the context.Changed status from 'Needs Triage' to: 'Confirmed'
Added subscribers: @dr.sybren, @Sergey, @brecht, @ideasman42
I am all up for using more OOP. But afraid it is a way bigger project than any other approach. And it might still need passing a context of some sort, maybe.
From future-proof point of view I think is best to refactor the code so that
BPY_driver_exec
receivesAnimationEvalContext
, even if it consists of a singleDepsgraph*
field. For the time -- i think we should not pass it explicitly, "just" get it fromdepsgraph
.TLS I do not like at all. Makes following the code more difficult, makes troubleshooting more difficult. And having a pool of worker threads which can evaluate different dependency graphs makes things sound fragile.
That's the "technical" aspect of the proposal. From the user level if will be "just" expression like
my_driver_evaluaiton_function(depsgraph)
?I think passing down both a
Depsgraph*
andfloat time
where needed through these functions is fine.The fact that the time may be different than the depsgraph time is weak, but I'm not sure how to avoid that without deeper NLA changes. I would just leave that behavior as is.
It would be good if we could actually make it so
bpy.context
is valid for access from Python drivers and app handlers. For Python drivers it would contain only data like scene, view layer and depsgraph. No UI, no active object, selected objects, etc. But I'm not sure how hard that is to implement. Either way, for that we'd also need to pass the depsgraph down to the driver function.I agree.
Yes. By putting
depsgraph
in the local scope we can treat it like any other Driver variable. I don't see another practical way to do this.I'm not a fan of having sets of parameters that are always passed to other functions in tandem. I think it's okay-ish to have a distinction between "fcurve/driver evaluation time" and "current depsgraph time", but if those are always passed together I'm more in favour of Sergey's
.I'll dive more into how exactly the Animated Strip Time in the NLA editor works, and whether that's really impacting drivers. Regardless, IMO it should be clear which functions operate on depsgraph time and which ones can receive an arbitrary time.
There is already a
_RestrictContext
Python class and an accompanyingRestrictBlend
context manager that do something similar while Blender is starting. However, this manipulates the globalbpy.context
, which is not something we want in this case. Instead of havingbpy.context
behave differently in different threads, we could documentbpy.context
access for drivers/handlers as "not allowed", and pass a suitablecontext
to the driver in its local variables.Added subscriber: @StephenSwaney
Added subscriber: @Mets
I don't think a
context
would providing anything that isn't already indepsgraph
, so I wouldn't do that.Documenting isn't really effective for this case because users are unlikely to be looking at the relevant docs when writing the wrong code. The original design for
Context
was definitely that it should have a different value in different threads, but instead it has become more of a global variable in both the C and Python code. Multiple threads using the same context is fundamentally broken, there's no way to use it reliably then.I'm not saying we have to solve this problem now though, just to me it seems like a more complete solution to this problem.
Added subscriber: @Russ1642
My experience is that passing around depsgraph objects is painful, prone to error, and difficult to debug. If there's a way to handle this in a more automated fashion then I'm all for that. It would be great if code didn't have to be completely rewritten just because you're rendering an animation rather than a still frame.
Why? It's the same as passing around the
context
parameter passed operators, and that's done all over the place.This is about drivers in Python, and all they have to do is replace
some_call()
withsome_call(depsgraph)
, and then use that instead ofbpy.context.view_layer.depsgraph
. I think calling this a complete rewrite is hyperbole.Added subscriber: @slumber
Added subscriber: @bblanimation
This was resolved in
686ab4c940
