Mesh Cache Is Evaluated When Display Type Is Bounds or Outline Display Flag Is Off #77115
6 Participants
Reference: blender/blender#77115
Operating system: Windows 7 SP1
Graphics card: nVidia GTX 660
Broken: version: 2.90 (sub 0), branch: master, commit date: 2020-05-08 16:22, hash:
6f985574b7
I noticed this when I imported an animated 266GB Alembic. I wanted to work on a camera move, so I set the imported object to bounds. I noticed no improvement in performance. Blender was still pulling all the Alembic data when the frame changed. I turned off the object in the outliner and I experienced the same problem. I tracked this down to the MeshCache modifier. Even when the object is turned off and set to show bounds, the modifiers are still evaluated. This problem may affect other modifiers as well.
A simple fix would be to not evaluate the MeshCache modifier if the object is not displayed or set to bounds.
Added subscriber: @AtomP
Added subscriber: @mano-wii
Can you provide a simple file showing the problem?
Added subscriber: @lichtwerk
In addition to providing an example .blend file:
I guess I can see your point about fetching the bounds from a deforming source. Perhaps there is a more efficient way to do that with with an Alembic file, which might already provide that data internally, instead of calculating it every frame?
However, when the object is turned off, by using the icon in the Outliner, there is no reason to evaluate any modifiers on that object.
I am attaching a simple example, that uses a highly subdivided Suzanne followed by an animated displace. When I scrub forward one frame, Blender takes time to revise the mesh. I turn off the mesh in the viewport, and try the same thing again. When I scrub forward one frame, I experience the same laggy mesh update that is then discarded and not displayed in the viewport.
Is there really a need to update mesh objects that are not displayed? After all, the user did turn off the display for a reason. My reason was to regain lost performance in the app, to work on a camera move. I do understand that there could be dependencies or drivers that may not update, but as the end user, I'm willing to accept that caveat. After all, everything will update as it should, once I re-enable the display flag.
29_modifier_timeline_update_issue.blend
Added subscriber: @iss
I can not reproduce this.
What are the steps?
Here is a snarky video that demonstrates how to reproduce the error.
reproduce_error.mp4
NOTE: If you have an amazing super computer (which most of us don't), try cranking up the subdivision count until you experience some viewport delay, then attempt what is demonstrated in the video, simply moving to the next frame with the Outliner visibility icon turned off for the Suzanne object.
I would expect, moving forward, that the datasets a user is going to pass through Blender are only going to get larger and larger. This Suzanne scene is simply a portable example file, As I mentioned in the first post, I was cranking a 266Gb Alembic through Blender when I discovered this performance bug.
Added subscriber: @dr.sybren
@AtomP Please keep the snarkyness out of these reports and keep the language clean. This is not the way to motivate people help you solve your problem.
As I see it, there are two different things reported here:
I've updated the manual for the 1st point in my previous comment. This leaves the "don't load Alembic mesh when drawing as bounding box" feature, which is interesting but will have to be designed & planned separately.
