Depsgraph not updating properly for frame_change_pre
handler #77126
5 Participants
Reference: blender/blender#77126
Operating system: Windows 10
Graphics card:
Broken: 2.83
Worked: Never
Depsgraph access in the
frame_update_pre
handler differs from viewport animation to render animation. It seems the global depsgraph does not update during render animation. I believe a simple solution would be to provide a depsgraph argument in theframe_update_pre
handler (similar to theframe_change_post
handler).Exact steps for others to reproduce the error
Based on the default startup:
Added subscriber: @bblanimation
Added subscriber: @mano-wii
Looks well related to #71908 if not the same problem.
Added subscriber: @dr.sybren
This is not the same as #71908.
The difference between viewport & render animation is as follows. In the viewport the depsgraph is "active", and thus the updates by the animation system are written back to the original datablocks. For rendering a new depsgraph is made (because all kinds of things have to be evaluated differently), which as a result is not marked as "active", and thus animation updates are not written back to the original datablocks. The problem here is that
bpy.context
will give you the viewport depsgraph, and not the render depsgraph. It'll thus always return the values as are currently seen in the viewport.As can be seen in
BKE_scene_graph_update_for_newframe()
(inscene.c
), updating the scene for a new frame happens as follows:BKE_scene_graph_update_for_newframe()
, the scene's current frame is updated to the new frame.frame_change_pre()
callback is called.frame_change_post()
callback is called.If that callback changed any data, the depsgraph is re-evaluated.
As you can see, in the pre-handler the depsgraph hasn't been updated for the new frame yet (hence the 'pre'). This can be used to change things around before the depsgraph is evaluated.
I agree that it is a good idea to explicitly pass the depsgraph here (also see #77086).
Added subscriber: @Sergey
Discussed with @Sergey, and this is not possible. The handler is not to be used as a "before the frame changes" handler, but as a "before the depsgraph updates". This means it can be used for adjusting the data & relations for the new frame. The depsgraph itself is intentionally not available, as it's out of date (i.e. it's not in sync with either the previous or the current frame).
I'll see this as a documentation task, as the code is working as intended.
This issue was referenced by
cdf0d95a50
Added subscriber: @barakooda
This comment was removed by @barakooda
