Mantaflow simulation is not simulating. #77135
5 Participants
Reference: blender/blender#77135
Graphics card: GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.92
Broken: version: 2.90 (sub 4), branch: master, commit date: 2020-05-27 10:07, hash:
efa4ae17f0
I have set up a simple scene with mantaflow. There is 1 domain, 1 body of fluid, and one flow source. It was working for a while, but the effector (volcano) stopped effecting the fluid at around frame 100. I added a physics domain to try and address this and tweaked a few settings and now when I try to run the simulation, nothing happens. The first frame shows the particles, but nothing changes after that. I removed the physics domain, still doesn't work.
volcano restart5 bug.blend
Added subscriber: @ScottVanKirk
#77134 was marked as duplicate of this issue
Here is another example of mantaflow not running the sim. Here I was playing with the size of the particles, trying to see what different settings would look like. The simulation stopped running and even returning the numbers didn't get it to restart.
This seems to be part of a larger problem with Mantaflow. It doesn't reset everything in the simulation as it should. For example, when I'm using "replay" mode, stop the simulation, then restart from frame one, My effectors often stop working as expected and after the previous stopping point the fluid just falls through the effectors with no interaction.
Again, I have been unable to reduce this any further since it occurs randomly as far as I can tell.
volcano restart6 bug.blend
Added subscriber: @ankitm
The thing with effectors sounds like the following task. Did you move the effector ?
#76095 (Liquid cache of type "Replay" doesn't get invalidated when moving participating objects)
No, nothing was moved, though I have seen that error as well.
Added subscriber: @iss
I can confirm, that liquid is not simulated. In this case it may be good to know, how to recreate this file from scratch, because files provided are fairly complex.
Can you give us steps to create example file?
I have spent hours trying to understand all the various failure modes of Mantaflow in replay mode with little success. If I can find the time, I'll try and track this down some more.
Okay, this might have something to do with changing the cache format to openvdb
I am not sure if this is useful as a bug report.
This files may got to state that looks OK for engine, and to fix the issue, actual workflow needs to be sanitized. So I could confirm this, but developer may ask you what exactly you did to get to this state.
You can definitely see this bug if you run a simulation, then change the cache format to openVDB. After that the simulation will not simulate.
Added subscriber: @lichtwerk
So this has been reported again, see #77432 (Mantaflow Liquid not work when "Data File Format" is changed to "OpenVDB") but this time straight to the point from the beginning [which will make the report a bit to understand].
Will merge these reports...
Closed as duplicate of #77432
