EEVEE: Render AO pass even when AO setting is disabled in Scene #77267
Closed
opened 2020-06-02 14:03:15 +02:00 by Jeroen Bakker · 6 comments
Member
In Blender 2.82 it was possible to render AO pass without having it enabled in the Scene. In Blender 2.83 you could only render the AO pass when it was enabled in the Scene. The reason behind this change is that rendering the AO pass influeces the light in EEVEE surface shading. There could be a case that the scene AO was disabled but as the AO Pass was enabled the AO was visible in the Combined and Light passes.
We could add some logic around the AO pass to bind the texture when performing the surface shading.
See https://devtalk.blender.org/t/issue-with-blender-2-83-vs-2-82-ao-is-this-a-bug/13514 for more context
In Blender 2.82 it was possible to render AO pass without having it enabled in the Scene. In Blender 2.83 you could only render the AO pass when it was enabled in the Scene. The reason behind this change is that rendering the AO pass influeces the light in EEVEE surface shading. There could be a case that the scene AO was disabled but as the AO Pass was enabled the AO was visible in the Combined and Light passes. We could add some logic around the AO pass to bind the texture when performing the surface shading. See https://devtalk.blender.org/t/issue-with-blender-2-83-vs-2-82-ao-is-this-a-bug/13514 for more context
Jeroen Bakker self-assigned this 2020-06-02 14:03:15 +02:00
Author
Member
Author
Member
Added subscriber: @Jeroen-Bakker
Author
Member
Proposed solution could be to attach a pixel as AO pass with the value indicating 'no occlusion horizon'
Possible difference when node_ambient_occlusion is being used. Need to test what this node does when AO is disabled.
Proposed solution could be to attach a pixel as AO pass with the value indicating 'no occlusion horizon' Possible difference when `node_ambient_occlusion` is being used. Need to test what this node does when AO is disabled.
Added subscriber: @ckohl_art
This issue was referenced by 68651534c2
This issue was referenced by 68651534c26346015a70775aef1fdadab2946fb6
Author
Member
Thomas Dinges added this to the 2.90 milestone 2023-02-08 16:27:16 +01:00
Reference: blender/blender#77267
