The shadow line is jagged in Cycles
Closed, InvalidPublic
Graphics card: GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.75
Broken: version: 2.83.0, branch: master, commit date: 2020-06-03 14:38, hash: rB211b6c29f771
Eevee vs Cycles (Shade smooth is activated).
It's been there for a long time.
NXSK (NXSK) added a subscriber: NXSK (NXSK).EditedJun 4 2020, 3:54 PM
I have the same issue
The sphere is subdivided by 10 times from a primitive cube and shaded smooth.
The lighting is very simple, just a HDR image.
But I still can see the light transition breaks between faces.
This looks like the shadow terminator problem to me. In 2.90 there will be an option to shift the terminator towards the light source, hiding the artifacts at the cost of energy conservation. See rBc7280ce65b856d26d6807c1b7a081ffc6311bfdc and D7634
@NXSK (NXSK)
Only one HDR image for light, primitive sphere with smooth shade, looks fine.
Make sure to use Catmull-Clark type instead of Simple type.
@NXSK (NXSK)
No. This is nothing to do with the subdivision surface modifier. If the normal is smoothed, the shading from viewer angle should be smooth, without any light breakups.
I think it might be the problem that robert says. And this issue might be there for a long time.
Phil Bao (bao007fei) added a comment.EditedJun 4 2020, 4:52 PM
@NXSK (NXSK)
For your situation, only one HDR for light. I tried and didn't see any light break problem. Maybe the texture is not perfectly seamless?
For me it only appears for built-in lights with low subdivision geometry.
This looks like the shadow terminator problem to me. In 2.90 there will be an option to shift the terminator towards the light source, hiding the artifacts at the cost of realism and lack of energy conservation. See rBc7280ce65b856d26d6807c1b7a081ffc6311bfdc and D7634
Good to know, Thanks:D
Hope it can be fixed completely someday without any extra options and costs.
@NXSK (NXSK)
For your situation, only one HDR for light. I tried and don't see any light break problem. Maybe the texture is not perfectly seamless?
For me it only appear for built-in lights with low subdivision geometry.
My texture is procedual. Some simple material won't show this issue.
And I'm curious about my previous work: a game flash light with low poly counts. Without normal map it still looks fine. But a sphere with a procedual carbon weave, it looks ugly, even if it is subdivided, just the jagged "teeth" becomes denser.
I asked my friends about this issue. They say Radeon Prorender and Octane render have the same issue. I think this might be the problem of path tracing shading algorithm.
Phil Bao (bao007fei) added a comment.EditedJun 4 2020, 5:21 PM
@NXSK (NXSK)
I've never seen this problem beyond Cycles. Really weird.
