cloth object connected to 2 rigid bodies does not animate correctly
Closed, DuplicatePublic
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 388.13
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-03-12 05:06, hash: rB375c7dc4caf4
Also Broken in version: 2.90.0 Alpha, branch: master, commit date: 2020-05-29 18:08, hash: rB2ee94c954d67
And in: 2.83 (sub 17), branch: master, commit date: 2020-05-29 09:59, hash: rB1d2b89304ac3
Cloth Object pinned to 2 rigid bodies does not animate correctly
  1. Open the attached SingleballoonAnimationBugReport2.blend file
  1. Play the animation and notice that there is
    • an animated cube called "connector" which is a passive rigid body,
    • a sphere called "ball" which is an active rigid body
    • An empty object called 'Constraint' which has a rigid body constraint of type 'point' applied between the cube and the sphere
    • A cylindrical object called 'string' which has a hook modifier applied to it, to connect it's top most points to the sphere. The 'string' is parented to the cube.
  1. Go to scene properties and notice that the gravity has a positive value in z direction, which is the reason for the ball to try to float away rather than fall down.
  1. Select the string object -> go to physics properties and apply 'Cloth'. In the Cloth settings, under Collisions dropdown disable the Object Collisions checkbox.
Now when you play the animation the string object doesn't move. This is wrong because the string is now suppose to float away while being connected to the sphere from the top end.
  1. In the Cloth settings go to Shape -> in the Pin Group datafield select 'pinned' vertex group. Play the animation and notice that the 'String Object doesn't animate like a cloth.
If I remodel the 'String' object and repeat the steps the animation sometimes work correctly. But this is quiet annoying as I have come across this issue in other places where there is cloth simulation. My final intention is to create a bunch of these animations but it's very hard to do as it sometimes do not work as there seems to be an annoying issue with the cloth animation that only works sometimes and fail in other times.
Thanks!
