GPencil: Dot Strokes is not working
Needs Information from User, NormalPublicBUG
Operating system: Mac mini (late 2014)
Graphics card: Intel Iris 1536 MB
Broken: 2.83 and 2.90
Worked: 2.83 Alpha
When you change the stroke mode type to dots or squares, it doesn't work.
Actually, even fill style is broken. Only Solid works.
On grease pencil material, just select the Dots Stroke and use it. It is not working.
guzu (guzu) added a project: Grease Pencil.
Antonio Vazquez (antoniov) changed the task status from Needs Triage to Needs Information from User.Jun 8 2020, 3:32 PM
This must be fixed with commit ef0ff4aaf251
did you test with 2D Template?
Antonio Vazquez (antoniov) renamed this task from Grease pencil Stroke Mode Type is not working to GPencil: Dot Strokes is not working.Jun 8 2020, 3:33 PM
@guzu (guzu) Be sure to check the Dot Strokes materials is set to Dots
Antonio Vazquez (antoniov) changed the subtype of this task from "Report" to "Bug".Jun 8 2020, 6:12 PM
guzu (guzu) added a comment.EditedJun 10 2020, 3:41 PM
Both dots and squares don't work in stroke mode.
Also,
Both gradient and texture don't work in fill mode.
Something must have went wrong after adding the vertex color feature.
Seems you are right. I've just tested it on windows platform and it works with no issues.
Probably it is a Mac only bug?
@guzu (guzu) can you test in a second Mac machine? maybe is configuration/driver problem.
guzu (guzu) updated the task description. (Show Details)Jun 13 2020, 7:37 PM
Unfortunately, it is the only Mac device I have. And Mac doesn't have much options to play with the drivers like in windows and linux.
I've changed something in the task. Blender 2.82 had a bug of disappearing grease pencil strokes, so the version that I was actually using is 2.83 Alpha and it had no issues.
guzu (guzu) updated the task description. (Show Details)Jun 13 2020, 7:46 PM
I think it effects only on OSX system with Intel GPU. On my Macbook(Intel GPU, Catalina, 2012) Grease Pencil with dots, gradients (T75061) and texture doesn't work.
hey, there is one more problem while inserting texture to the material for GP, the blending option does not work properly, it worked fine in 2.82 as it did not have the blending option. i saw a tutorial in which blending option was working fine, i guess he was using windows but in mac we have this issue.
