Remove the Threaded Sculpt option from menus
Closed, ResolvedPublicDESIGN
If threaded sculpt is causing performance problems (which in some cases it does), those should be considered a bug instead of letting the user disable multithreaded. Removing this option from the menu will help to simplify the UI.
I would say we should keep the option in developer extras as it is helpful when debugging tools to check if artifacts are caused by multithreaded access to data.
Revisions and Commits
