2.83.0 Power Sequencer addon alt+up or alt+down arrow acts differently after the first usage #77671
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#77671
Operating system: Windows 10 Home 2004
Graphics card: RTX 2070 Super
Broken: version: 2.83.0, branch: master, commit date: 2020-06-03 14:38, hash: 211b6c29f771, type: Release
build date: 2020-06-03, 12:41:58
Worked: ?
open blender as "video editing"
1- add a movie strip
2- add another shorter movie strip
3- select the shorter strip
4- hit ctrl+alt+down arrow
5- shorter strip divided and placed in other strip
6- repeat 1-3 steps again
7- hit alt+down arrow
8- expecting the shorter strip place under the other strip, it behaves like we hit ctrl+alt+down arrow
alt+down arrow always behaves ctrl+alt+down arrow from now on until we reopen the blender
video shows : youtube video
Added subscriber: @BaranYagcioglu
Added subscriber: @iss
I can confirm, I think I saw this bug previously, and it happens for all keymaps with ctrl+alt modifier keys.
I will have to investigate more, if this happens everywhere or only in VSE layout.
Added subscriber: @Sergey
Could also be related on "Save property value for the next operator run". In this case "just" assign all operator properties in the keymap and see if that helps.
This did not help when I edited keymap manually. In adjust last operation I saw that operator properties did not correspond to keymap. Don't see how this flag can be set/cleared from python. Will check this on C side as well.
Checking with C operator I can reproduce only with operator property, that doesn't have
PROP_SKIP_SAVE
set, so that is probably the issue here indeed. And that works correctly.As for addon functionality, this resolved the problem:
Will have to look if it is possible to do equivalent of
RNA_def_property_flag(prop, PROP_SKIP_SAVE);
in python.That being said, I will change this report to addon issue only.
Added subscriber: @GDQuest
Ah, found it: https://docs.blender.org/api/current/bpy.props.html#bpy.props.EnumProperty
You can pass
options={'SKIP_SAVE'}
@GDQuest you may be interested in setting this flag for more opeators to prevent this issue.
Added subscriber: @Tabra
I solved this issue (and many more) directly in the addon's git
