Driver access to 'self' property is outdated when changed from app handler #77700
Reference: blender/blender#77700
Operating system: Windows 10
Graphics card:
Broken: 2.83
Worked: Tested as far back as 2.80 with no luck.
It seems that drivers which access 'self' properties remain outdated by one frame, when the 'self' property in question is updated on frame change with an app handler.
Added subscriber: @bblanimation
Added subscriber: @dr.sybren
@bblanimation That's quite a lot of script for a minimal example. Are you sure it's not possible to reduce it? For example, is it really necessary for this issue to show up to have a
poll()
function that always returnsTrue
? Is tagging for redraw really necessary, or can aprint()
statement to the terminal suffice?Changed status from 'Needs Triage' to: 'Needs User Info'
@dr.sybren That's fair! I went ahead and reduced the code quite a bit, and refined the description a bit to help clarify things. Happy to add/adjust anything else if needed.
Added subscriber: @mano-wii
Oops my bad
@bblanimation The code uses
bpy.context.view_layer
, which has been shown to be dangerous to access from drivers in #75553. The solution for that is currently under review (D8047). Basically any Python code that's run from a driver or a callback or anything else that gets a context or a dependency graph from Blender should be using that context/depsgraph, and notbpy.context
.This is not the root of the issue, though. The problem is caused by using
frame_change_post()
; this is called by Blender after the dependency graph has been evaluated (hence the 'post' in the name). This means that first the driver is evaluated, and only then is theupdate_test_value()
function called. The best way is to useframe_change_pre()
as a callback, as that is called before the depsgraph is evaluated for the next frame. Note that in this case the scene frame number is already set to the next frame. The 'pre' in the function name means 'before the depsgraph evaluation', and not 'before the frame changes'.Alternatively you can tag the cube for update with
obj.update_tag()
inupdate_test_value()
. When this is done from a frame-change-post handler, it will trigger a second evaluation of the depsgraph, making sure that the driver picks up the new value. This could be a less performant solution, though.In any case, this doesn't seem to be a bug in Blender.
Just a bit of Python education, because I can't help it:
print("Test value (%(fc)s):" % locals(), round(obj.test_value, 2))
-- damn, that's some complex stuff. Just write this:Same for this:
I think that can be rewritten as something more readable like this:
Where, after D8047 has been applied,
view_layer
should be obtained from the depsgraph that's passed to the driver.
