Broken: Since ShaderFX were added
Worked: Never
Changing shaderFX and using their operators sends update notifications for modifiers. Presumably this is because the modifier code was duplicated without changing these lines. See these lines in object_shaderfx.c:
WM_event_add_notifier(C, NC_OBJECT | ND_MODIFIER, ob);
The properties area is only updated per tab, and since shaderFX added a new tab, there should be a corresponding ND_SHADERFX as well.
- Have two different property areas with the effects tab open.
- Change data in one area
- See the other area not update
