Sculpt persistent mesh state management #77738
Reference: blender/blender#77738
The Layer Brush has a "Set Persistent Base" operator that stores a copy of the mesh coordinates and normals using the sculpt API. This is needed for that brush to be usable, but it has some problems:
Furthermore, this same concept is needed in other tools to fix some important limitations:
As this is a concept similar to shape keys which will probably be similar to sculpt layers, there are still a lot of design decisions to be made to have a final solution for this:
Proposal
As having a workaround for this could improve a lot some of the tools, the sculpt API could implement a ##SCULPT_vertex_get_persistent_co## function. The function will use the same implementation as the current layer brush, so it will return the data stored in the persistent base if available. This will mean than tools like the cloth brush and the pose brush will have a "persistent" and "set persistent base" properties and operators available. Once a more polished management system is in place, it should only be necessary to change the implementation of that function to return the data from the current persistent base wherever it is stored.
This issue was referenced by
a3e6b7c2ce
To me it seems persistent base as used by the layer brush should be a temporary state in sculpt mode, that you can create or discard as easily as a mask. Maybe sculpt layers can eventually replace it, if it's convenient enough to create and sculpt on a temporary layer that you then merge into the layer below.
I wouldn't go in the direction of using persistent base for something like a T pose or undeformed mesh shape. For that I think shape keys or sculpt layers are the correct solution.
