I can't save a startup file
Closed, DuplicatePublicBUG
Graphics card: GeForce RTX 2070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.28
Broken: version: 2.83.0, branch: master, commit date: 2020-06-03 14:38, hash: rB211b6c29f771
I find it very useful to be able to save a startup file.
I'm transforming hundreds of SVGs as FBX to import into Unity.
Normally I'm able to save my script, my layout without any camera or lights.
Not being able to make an adjustment to the default layout I'm forced to find a work-around.
Please reinstate this function.
  • open Blender 2.83,
  • click on the Script tab
  • to create a new text file,
  • copy and paste this code into file:
import bpy
bpy.ops.object.convert(target='MESH')
bpy.ops.object.editmode_toggle()
bpy.ops.mesh.select_all(action='SELECT')
bpy.ops.mesh.remove_doubles()
bpy.ops.mesh.beautify_fill()
bpy.ops.object.select_all(action='SELECT')
bpy.ops.mesh.flip_normals()
bpy.ops.object.join()
  • click on Layout tab,
  • select all,
  • erase all,
  • click File>Defaults>Startup File,
  • click Save Startup File.
  • close program and reopen it.
if you see nothing has changed then do the Macarena and squawk like a chiken.
We're never gonna survive unless, we get a little crazy. :)
I hope this oversight is managed quickly.
And I do appreciate this tool and the work that has gone into it.
So, thank you very much.
Same here, with the same version and same environment, can reproduce this issue on three of my computers.
I also keeped a blender 2.82a which works fine, then I tried to copy my 2.82a userpref.blend file from %APPDATA%\Blender Foundation\Blender\2.82\config\ to %APPDATA%\Blender Foundation\Blender\2.83\config\, then it works properly, the 2.83 "Save Startup File" menu option also works as expected after I did that. Following is the working userpref.blend file from my 2.82 config folder, hope it can be a workaround before a fix comes out.
Thank you Sir Gary,
you are an officer and a gentleman.
I'll just offer a little suggestion and that's not to be ungrateful.
I think it would be better if you lay out your instructions in point form.
I'll do so here in case someone else stumbles on this thread.
Blender 2.83's function to save user settings doesn't work.
Both Gary and myself have experienced this issue, Gary having made several attempts on different computers.
The workaround is this...
  • You must have an earlier and working version of Blender installed such as 2.81 or 2.82. -
1 - In Windows press Windows Key and E on your keyboard (or open the file explorer without the shortcut)
2 - Copy this:
You may be using a different version of Blender like 2.81 so you will want to make that adjustment manually
and paste it into the address bar (If what is being referred to is not clear, the address bar displays where the folders and files are located on your computer... example C:\Users\Bob\Documents)
press Enter
3 - In this location you will see a file named
userpref.blend
This is the file you need to copy to then paste it in the location of your new installation of Blender.
As you can see, it's the same file structure for the new blender.
4 - Now you can open Blender 2.83 and your settings will be adjusted to your preference.
Thank you, and this has not been a paid message.
May you go with God, may life be kind, may your children grow strong and make you proud.
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Needs Information from User.Tue, Jun 16, 4:06 PM
I cannot reproduce this with either the latest stable or current development versions of Blender:
Please try the latest daily build: https://builder.blender.org/download/
Maybe there is a setup on the computer that needs to be described in the steps to reproduce the bug?
Germano Cavalcante (mano-wii) changed the task status from Needs Information from User to Confirmed.Wed, Jun 17, 3:21 PM
Germano Cavalcante (mano-wii) triaged this task as High priority.
I can confirm with the official version of blender 2.80, installing through the installer (not the zip)
Germano Cavalcante (mano-wii) changed the task status from Confirmed to Needs Information from User.Wed, Jun 17, 3:24 PM
Germano Cavalcante (mano-wii) lowered the priority of this task from High to Normal.
False alarm. (I mistook "Save Startup File" for "Save preferences")
To reproduce this issue, we need a clean environment with blender 2.83 just installed. I use the zip version instead of the installer. The reproduce steps:
  • Make sure your computer never run blender 2.83 before, or by remove all the files under '%APPDATA%\Blender Foundation\Blender\2.83\config\'
  • Open blender 2.83 by double clicking the blender.exe executable (FYI, build hash: 211b6c29f771).
  • Just delete the default cube.
  • Click File>Defaults>Startup File, click Save Startup File.
  • Close the program and re-open it.
  • Check the result (the default cube is still there).
My environment is Windows 10 version 1909 (18363.900).
For the workaround I provided above:
  • Do the above steps to reproduce the issue first.
  • Copy the working 'userpref.blend' file form my 2.82a folder ('%APPDATA%\Blender Foundation\Blender\2.82\config\') to '%APPDATA%\Blender Foundation\Blender\2.83\config\'. (or use the one I uploaded here, I guess it will also works)
  • Open blender 2.83, and we can see the default cube is deleted which means it's working.
It seems the start-up file is saved but blender is still loading the factory preset instead of the user custom startup file..
Let me know if you need any additional info. Thanks.
Just tested this issue under my Archlinux/KDE installation with blender installed from official Arch repo (blender 17:2.83-1), do the exact same steps, and also can reproduce this issue.
  • Make sure your computer never run blender 2.83 before, or by remove all the files under '~/.config/blender/2.83/config/'
  • Open blender 2.83 by double clicking the blender application icon from the plasma application dashboard (FYI, build hash: 211b6c29f771).
The above workaround also works:
  • Copy the working 'userpref.blend' file form my 2.82a folder ('~/.config/blender/2.82/config/') to '~/.config/blender/2.83/config/'.
Germano Cavalcante (mano-wii) changed the task status from Needs Information from User to Needs Triage.Thu, Jun 18, 3:40 PM
This report is already getting very confusing.
A lot of pertinent information is scattered in the comments.
And I'm not sure which to look at first.
This is too time consuming for us to track down and we require the bug reporter to narrow down the problem.
Please, could you make another report showing in a few steps how to reproduce the problem?
I believe my reproduce steps is the minimum one, you just need to make sure your environment is clean and do a "delete the default cube and save it as startup file" steps.
Here you go https://developer.blender.org/T78037 :)
