Mantaflow - liquid refuses to rise above level of inflow object #77827
7 Participants
Reference: blender/blender#77827
Operating system: Windows 7 Pro - 64-bit
Graphics card: Nvidia GeForce GTX 1060 6gb
Broken: blender-2.90.0-fd8d245e6a80-windows64
Worked: 2.83
Here is what appears to be a bug in the Mantaflow liquid calculations in Blender 2.90
In the first Blender file - manta_vol_bug.blend - the inflow object is within an effector-collision object. When the simulation runs the level of the fluid refuses to rise above the Z-axis of the inflow object. This behaviour does not happen with this file in Blender 2.83
It must also be noted that there is a severe difference of the liquid inflow rate using the same simulation numbers between version 2.83 and version 2.90. That may be a problem on its own, but I cannot say if this has any influence on the Z-axis volume bug that I am seeing.
I have uploaded two video files of the rendered results of this file.
I have also uploaded a second Blender file - mantaflow volume_bug 02.blend - where the volume flow relative to the Z-axis of the inflow object is more obvious. Strangely enough, this file when loaded into Blender 2.83 will show the same incorrect behaviour.
manta_vol_bug.blend
manta_volume_bug_283.mp4
manta_volume_bug_290.mp4
liquid flow bug_290.mp4
Added subscriber: @ignatz
#101304 was marked as duplicate of this issue
This problem is now showing up in the latest release: v2.83.1 LTS
Added subscribers: @sebbas, @JacquesLucke
The difference seems to be caused by
21485e94aa
.In particular, by the change to these lines:
Unfortunately, I do not know if the old or new behavior is correct. @sebbas, is inflow supposed to work when the inflow object is under water?
Just adding my opinion here:
If the Mantaflow liquid simulation is meant to reflect real world behaviour then, 'yes', an inflow object that is under the surface of a fluid should still be able to 'pump' water into the tank, vessel, domain or what have you.
Yes, ideally an inflow object should act like a water tap and continuously add fluid to the scene.
Right now though, any inflow object will never add more fluid than "its own highest level". This can be seen when minimising the forces in the scene (i.e. no initial velocities and near zero gravity) - the level of fluid should not go higher than the inflow object itself.
Once the forces are higher and there is some splashing going on you will see fluid levels increasing. Fluid can expand better and this can, for example, lead to the impression of a bucket filling up. In the 2.83 scene the gravity forces were a bit stronger and so it did a better job of filling up the bucket.
Can this be behaviour be improved? Certainly! Ideally, there should be a force that counters gravity and pushes fluid particles up once an area has been filled up with fluid.
I am tagging this as a known issue for the time being.
Added subscriber: @thinsoldier
Added subscribers: @liang-yunfei, @OmarEmaraDev
