Mantaflow (GAS) The simulation does not work correctly when using an object for collisions. #77833
Reference: blender/blender#77833
Graphics card: GeForce GTX 1070 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 446.14
Broken: version: 2.83.0, branch: master, commit date: 2020-06-03 14:38, hash:
211b6c29f7
Worked: 2.82a
The "Collision" effector is installed on the rings. When the rings begin to rotate, the smoke does not move correctly. And in the end, the simulation explodes.
opengl0001-0093.mp4
The same simulation, but made in Blender 2.82a
opengl_2.82a.mp4
collision.blend
Added subscriber: @YuraKharitonow
Added subscriber: @iss
This file is very complex. Takes too much time to bake. Is is possible to create simpler example file? Ideally as simple as possible.
I can’t repeat the “explosion” of the simulation on the low domain settings.
After running a few low-resolution tests on the domain, I noticed that Noise affected the simulation behavior.
Below is a video without noise.
without_noise0001-0150.mp4
Below is the same simulation, only with noise. Level 1
with_noise0001-0150.mp4
I also found a video on YouTube, in which you can see the "explosion" of the simulation. This happened with Noise enabled.
https://youtu.be/df7_yW_9-M8?t=123
I post the file with my new example.
noise.blend
And one more example with Noise.with_noise0001-0150.mp4
It turned out to repeat the unstable simulation at a resolution of 200. No noise.
Fire and smoke should be from the first frame, but they are not. In the end, the simulation is very unstable.
1)Select a torus and bake the particle system.
2)Choose a domain and bake gas.
collision.blend
I tried to bake the simulation with a resolution of 150. And I noticed that if the simulation is paused, the simulation will be unstable at the end.
Below is a video in which I paused the simulation twice.
without_noise02.1_with_pauses0001-0150.mp4
And in this video, the simulation is without a pause.
without_noise020001-0150.mp4
Maybe it's a pause. But the noise is clearly baked incorrectly (examples are above).
collision.blend
Added subscriber: @sebbas
So, there is now a fix in master (
663e047102
) which resolved similar issues. I was also able to bake the attached scene and got a stable result - I'm therefore calling this issue resolved.@YuraKharitonow If you have a chance to bake the simulation with the latest master that would be great - just to confirm the fix or prove me wrong :)
