Eevee won't display reflections from world environment HDR texture #77891
Closed
opened 2020-06-15 17:11:19 +02:00 by Mendes · 13 comments
Operating system: Microsoft Windows 8.1 Single Language
Graphics card: Intel(R) Graphics HD 4400
Broken: 2.83 LTS, as available on blender.org
Upon creating a scene with an world environment texture, and adding a Principled BSDF material with 1.0 Metallic and low roughness, the reflections of the world texture do not appear on the object's (standard cube) surface. The direct light reflection, however, does appear. A few additional details of the bug can be found here .
Change the render engine to eevee, change Viewport Shading to Rendered, or render from the camera, as is.doesntwork.blend
**System Information** Operating system: Microsoft Windows 8.1 Single Language Graphics card: Intel(R) Graphics HD 4400 **Blender Version** Broken: 2.83 LTS, as available on blender.org **Short description of error** Upon creating a scene with an world environment texture, and adding a Principled BSDF material with 1.0 Metallic and low roughness, the reflections of the world texture do not appear on the object's (standard cube) surface. The direct light reflection, however, does appear. A few additional details of the bug can be found [here ](https://blender.stackexchange.com/questions/182723/metallic-reflective-material-not-displaying-reflections-of-the-world-hdri-on-ee). **Exact steps for others to reproduce the error** Change the render engine to eevee, change Viewport Shading to Rendered, or render from the camera, as is.[doesntwork.blend](https://archive.blender.org/developer/F8621640/doesntwork.blend)
Author
Added subscriber: @emanuelmendes118
Member
Added subscriber: @lichtwerk
Member
Member
Looks like this here
Your GPU is on the lower end of the supported spectrum.
Please double-check if the drivers are up to date and the hardware meets Blender's requirements: https://www.blender.org/download/requirements
To upgrade to the latest driver, see here for more information: https://docs.blender.org/manual/en/dev/troubleshooting/gpu/index.html
Please report back if this fixes your issue, thx.
Looks like this here ![image.png](https://archive.blender.org/developer/F8621826/image.png) Your GPU is on the lower end of the supported spectrum. Please double-check if the drivers are up to date and the hardware meets Blender's requirements: https://www.blender.org/download/requirements To upgrade to the latest driver, see here for more information: https://docs.blender.org/manual/en/dev/troubleshooting/gpu/index.html Please report back if this fixes your issue, thx.
Author
I used the OpenGL Extension Viewer to check if it's working, and the tests seem to indicate the API is working as expected, with all versions required for running Blender being supported. image.png
I am also attaching the system-info.txt file, in case it contains useful information.
If any further information becomes necessary, I'll be glad to provide it. Thank you.
system-info.txt
The video graphics adapter driver seems to be up-to-date. ![image.png](https://archive.blender.org/developer/F8625227/image.png) I used the OpenGL Extension Viewer to check if it's working, and the tests seem to indicate the API is working as expected, with all versions required for running Blender being supported. ![image.png](https://archive.blender.org/developer/F8625333/image.png) I am also attaching the system-info.txt file, in case it contains useful information. If any further information becomes necessary, I'll be glad to provide it. Thank you. [system-info.txt](https://archive.blender.org/developer/F8625369/system-info.txt)
Author
Not sure how this works here, but, shouldn't the task status be altered now?
Member
Added subscriber: @mano-wii
The website to download the graphics driver shows that the latest version is 15.40.45.5126 (and not 10.18.14.5117).
https://downloadcenter.intel.com/product/81497/Intel-HD-Graphics-4400
Are you sure you have installed the latest version of the Intel Graphics HD 4400 driver?
The website to download the graphics driver shows that the latest version is `15.40.45.5126` (and not `10.18.14.5117`). https://downloadcenter.intel.com/product/81497/Intel-HD-Graphics-4400 Are you sure you have installed the latest version of the Intel Graphics HD 4400 driver?
Author
I downloaded and installed the aforementioned driver for Windows 8.1 and my Processor, I tried uninstalling the driver, restarting, then installed the downloaded one. The installation manager showed that 10.18.14.5117 was the latest version for the graphics card, and, again, both the intel driver support and opengl viewer said the driver was up to date after I installed it.
The results on Blender remained the same. Maybe - [x] detail I forgot to mention is that the material preview works fine.
In short, yes, I am sure this is the latest driver.
I downloaded and installed the aforementioned driver for Windows 8.1 and my Processor, I tried uninstalling the driver, restarting, then installed the downloaded one. The installation manager showed that 10.18.14.5117 was the latest version for the graphics card, and, again, both the intel driver support and opengl viewer said the driver was up to date after I installed it. The results on Blender remained the same. Maybe - [x] detail I forgot to mention is that the material preview works fine. ![image.png](https://archive.blender.org/developer/F8656098/image.png) In short, yes, I am sure this is the latest driver.
Closed as duplicate of #75943
Reference: blender/blender#77891
