Vertex Weight Proximity modifier missing falloff type custom curve #77906
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#77906
Operating system: Windows 10
Graphics card: GeForce GTX 770
Broken: 2.83.0, branch: master, commit date: 2020-06-03 14:38, hash: 211b6c29f771, type: Release (from system info text file)
Worked: Unknown
Vertex Weight Proximity modifier missing falloff type custom curve.
Should be present according to manual documentation https://docs.blender.org/manual/en/2.83/modeling/modifiers/modify/weight_proximity.html
Found using default startup file.
Added subscriber: @David_Haley
Added subscriber: @mano-wii
It may be an error in the manual, in the interface, or a limitation of the modifier.
You can't know for sure without further investigation.
Confirming as a bug for now.
Added subscriber: @Blendify
It currently is not implemented for this modifier, judging by the comment however, I am not sure if this is intentional or a limitation:
I fixed the documentation in the meantime.
Added subscriber: @mont29
Definitively not a bug, was probably a mere copy/paste mistake when I wrote those docs at some point or another...
