Increased Sampling Noise when Rendering the World Background in Cycles. #78056
Reference: blender/blender#78056
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.19
Broken: version: 2.83.0, branch: master, commit date: 2020-06-03 14:38, hash:
211b6c29f7
Worked: 2.82a
There seems to be a differing amount of noise when rendering the world background between 2.82 and 2.83 in Cycles. I can't work out whether this noise is actually increased or if it's just different. In any case, it appears that the noise in 2.82 is more uniform and 'correct'. Tweaking the levels for better viewing (see the attached gifs) makes it appear as though in 2.82 the noise was perhaps more spread out and there were both lighter pixels and darker pixels, whereas in 2.83 the noise appears closer together and there are far fewer lighter pixels, seemingly making it more noticeable. Is this intended behaviour?
Both gifs are of default cube renders in each version using identical settings @ 512 samples.
Default Scene 2.82a.blend
Default Scene 2.83.0.blend
Added subscriber: @Hexbob6
Added subscriber: @mano-wii
512 samples don't bring that much noise in my case.
But I confirm that they are different. Although I can't say if it's more or less noiser.
The settings are the same and the release notes do not indicate what may have brought this change:
https://wiki.blender.org/wiki/Reference/Release_Notes/2.83/Cycles
Added subscriber: @brecht
Please attach a .blend file to reproduce the problem.
Also ensure you have not enabled adaptive sampling, which does not exist in 2.82.
I have uploaded 2 test files, each are default scenes saved in their respective Blender versions. Adaptive Sampling isn't enabled in the 2.83.0 version. I've also tested the sampling differences between one of the Beta versions of 2.82 (
c939b4df18
), against 2.82a and found that the noise pattern is identical. I can upload references if needed.Changed status from 'Needs User Info' to: 'Archived'
In these default scenes, all the noise is coming from dithering (this can be disabled in Output Properties > Post Processing).
This is an intentional change from
852cdd4
. The goal of dithering is to approximate the color as close as possible, and the previous code was off by 0.5/255 which gives more lighter and darker pixels with the default background color, but with another background color it will be different again.
