Crash using shader #78068
Reference: blender/blender#78068
Operating system: Darwin-19.5.0-x86_64-i386-64bit 64 Bits
Graphics card: Intel(R) Iris(TM) Plus Graphics OpenGL Engine (1x6x8 (fused) LP Intel Inc. 4.1 INTEL-14.6.18
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-19 21:56, hash:
466e716495
Blender Crashes when ever I try to use shading if I add a component to it it freezes and crashes
I added mix shader then emisson and colorramp and its frizez (its only happens when I use shading)
can't resolve the issue
making a world (blender carsh).blend
Added subscriber: @Kevin.R
Added subscriber: @Josephbburg
Hello, it doesn't look like your hardware is supported. I'm having trouble checking your graphics card-- do you mind telling me your CPU so I can check which specific Iris device you're running? Thanks.
This comment was removed by @Kevin.R
Hi it's a inter core 3
That's not enough information to go on -- what is the model number? There are a lot of different i3's.
It's a 2020 macbook air
The model number is A2179
Hi Joseph brandenburg I'm just writing because it's still doesn't work so can you please reply soon as possible and thank you
That's pretty new, actually, so it should be supported. I wonder if the problem is because you're using a Mac? Any chance you could run Blender from a terminal and post the crash message here?
Well that's the thing I tried it on my brothers mac because he has an 2019 macbook air and it worked perfectly so I dont know what's the problem.
ResolveDebug_3.txt
Hi is that enough information or you need more ?
Unfortunately without a Mac to test things on I don't think I can be much more help. But if there is ever more information to post -- always post it.
... and please don't upload text documents on this site. You can upload large blocks of text like this:
Maybe if I can open the debug text somehow, I can help, but I think it's probably just unsupported hardware.
EDIT: firefox was just being stupid. I will take a look now.
This doesn't look like a Blender log or terminal output. It says "DaVinci Resolve" a bunch of times and talks about Metal, which is not compatible with Blender.
Added subscriber: @fclem
Can you test if previous version of blender works (like 2.83, 2.82...) to see if the problem has been introduce recently?
Can you also give us the result of running blender using the
blender --debug --debug-gpu --debug-gpu-force-workarounds
in a terminal?Can you also provide the
system-info.txt
that you can save from the help menu?Added subscriber: @ideasman42
More than a week without reply or activity.
Due to the policy of the tracker closing for until required info/data are provided.
If the problem persists please open a new report with the required information.
