Material preview with eevee render engine shows pink color regardless of material settings.
Closed, DuplicatePublic
Operating system: Windows 10 (Version 1809, Build 17763.1282)
Graphics card: Intel(R) UHD Graphics 620 (Version: 4.5.0 - Build 26.20.100.7528)
Broken: 2.83.0, branch: master, commit date: 2020-06-03 14:38, hash: 211b6c29f771
Worked: 2.80.0....beta
Material preview shows pinkish colors regardless of material settings. The screenshots attached show default material. Sometimes the icons in material list are rendered in pink as well. Rendering Images result in pink objects regardless of material settings as well. This issue is not present, if cycles render engine is used.
This issue might be related to "Pink Material Preview and Principled BSDF Shader", https://developer.blender.org/T72170
  1. Open a new blender Document
  2. Open material properties
  3. Resize preview panel
Material panel:
Material panel after resize of preview panel:
Rendered image:
Comment: This might be related to "Pink Material Preview and Principled BSDF Shader", https://developer.blender.org/T72170
What is the output if you launch blender using the debug and debug_gpu batch files?
Thanks for the fast response! You can find the requested log files attached.
As described in T77944: Material Preview (and final render in EEVEE) purple I get pink/purple color several times too: Resizing the preview panel size is not the only way to produce purple color. I can confirm these effects:
T77944: Material Preview (and final render in EEVEE) purple:
  • pening a preview (in my case the material icon becames purple here, but the preview itself often can be normal yet in 2.83)
  • changing a Preview Render Type (it "paints" the object and the plane unpredictably, but most times it's purple every time when switching, as in screenshots in the description. For example, every part of a Shader Ball can be either grey or purple color)
  • changing something in material shader (for example, a Base Color)
  • using Material Preview viewport shading
  • Render itself
On rare conditions preview rendering (and eevee rendering) works fine. Unfortunately, I cannot make out specific conditions to get purple or correct preview colors. Changing the preview size leads to purple colors every time!
In my opinion this ticket can be marked as duplicate of T77944: Material Preview (and final render in EEVEE) purple.
