Hidden Hair Particles hard to separate from non-hidden [2.79 draws them with les opacity]
Closed, DuplicatePublicTO DO
Graphics card: GeForce GTX 950M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 398.35
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-24 21:51, hash: rBec776f18ff70
Worked version: 2.79
Сhose particles and hid them, but they are still visible. Imposible to work! In 2.8 was this problem, and again!
Related Objects
Ankit (ankitm) changed the task status from Needs Triage to Needs Information from User.Thu, Jun 25, 7:26 PM
Ankit (ankitm) added a subscriber: Ankit (ankitm).
Please share a simple blend file to help test it, and steps to make it from scratch.
Ankit (ankitm) renamed this task from Particle not hide to Selected particles not hiding.Thu, Jun 25, 7:26 PM
Just checking if I understand correctly:
This is 2.79
This is 2.90
Both display the hidden particles still (2.79 did this with a bit lower opacity, true -- is this what we are talking about?)
For the children: looks like both 2.79 and 2.90 display these regardless of the parent visibility.
Please tell me if I am missing something.
CHET (cheteron) added a comment.EditedThu, Jun 25, 10:42 PM
Yes, 2.79 there have transparent, and particles can be separated by depth. If you noticed in my screenshot, all the particles turned into one mass, and it is not clear what is hidden and what is active, there is no exact separation of the particle.
Philipp Oeser (lichtwerk) changed the task status from Needs Information from User to Confirmed.Fri, Jun 26, 11:15 AM
Philipp Oeser (lichtwerk) changed the subtype of this task from "Report" to "To Do".
OK, lets keeps this as TODO then, [at least when T68981 gets done].
This really reads better in 2.79.
Philipp Oeser (lichtwerk) renamed this task from Selected particles not hiding to Hidden Hair Particles hard to separate from non-hidden [2.79 draws them with les opacity].Fri, Jun 26, 11:18 AM
Thank you!
@CHET (cheteron) Do not open multiple tickets for the same issue. This known issue is going to be solved at one point. Just be patient.
I did not open the duplicate. The previous request is also mine, and it was somehow fixed, and then broke again. If you are not up to date, do not write nonsense
