Mantaflow: changing flow type (fire -> fire + smoke) resets Surface Emission
Closed, ResolvedPublicBUG
Graphics card: AMD Radeon R9 200 Series ATI Technologies Inc. 4.5.13587 Core Profile Context 20.2.2 26.20.15019.19000
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-19 23:28, hash: rB874af5301cdf
Changing flow type, the Volume Emission keeps its value but Surface Emsission resets to 1.5 (default)
Add Fluid to the default cube, select flow. Then write 1 into Surface Emission and 1 into Volume Emission. Then change to Fire + Smoke. Volume is unchange, Surface no.
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Confirmed.Jun 26 2020, 3:57 PM
I'm not sure which properties should be reset.
But at first it looks like a bug.
The idea of changing the Surface Emission when changing the flow type was that liquid flows should have a different default value than smoke/fire flows.
The issue you describe should not happen though.
I have made some changes so that the Surface Emission is only changed when changing the flow type from Smoke/Fire+Smoke/Fire to Liquid or, vice-versa, when changing from Liquid to Smoke/Fire+Smoke/Fire.
