Cycles: split kernel error: failed to load kernel_subsurface_scatter
Closed, ResolvedPublicBUG
Graphics card: AMD Radeon RX 5700 XT ATI Technologies Inc. 4.5.13596 Core Profile Context 20.5.1 27.20.1017.1011
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-22 12:03, hash: rB85c6f0b472ed
Worked:version: 2.90.0 Alpha, branch: master, commit date: 2020-06-19 23:28, hash: rB874af5301cdf
When in cycles, trying to render with the GPU in openCL doesn't work, resulting in the message in the title of this report or sometimes in a crash.
Rendering anything in cycles openCL is giving me this problem. I already tested with the default blender settings and it still doesn't work. It only happens in 2.9 and GPU, in CPU it works with no problem.
I'm creating this bug report after I closed T78166 thinking the problem was gone but it turns out I just forgot to setup gpu rendering in settings, sorry for this.
Extra notes:
-When I switch to rendered view, it starts loading the kernels and it takes a bit longer than usual until the error appears
-Sometimes it doesn't even load the kernels, it just crashes.
-The highest version I have that it works is from june 19 and the lowest it doesn't is june 22.
-All tests I did where with default settings.
System-info
File obtained from running the GPU debug mode:
File obtained from running the GPU debug mode when crashing:
File obtained from running debug mode when crashing
Diogo Valadares Reis dos Santos (DiogoX2) changed the subtype of this task from "Report" to "Bug".
In the day I oppened this report Brecht Fixed this in rBfb68a30af6e1.
