Blender Crashes if I close the render window #78362
Closed
opened 2020-06-27 17:53:17 +02:00 by Mike Lima · 16 comments
Operating system: macOS Catalina 10.15.5 . 19F96
Graphics card: NVIDIA GeForce GTX 660M 512 MB
Broken: (Version 2.83.0 (2.83.0 2020-06-03))
Blender crashes if I close the render window, while it is still rendering.
  1. Open a scene and start rendering.
  2. the rendering window will open showing the render as it progresses.
  3. While it is still rendering, close that window.
  4. Boom... crash.
**System Information** Operating system: macOS Catalina 10.15.5 . 19F96 Graphics card: NVIDIA GeForce GTX 660M 512 MB **Blender Version** Broken: (Version 2.83.0 (2.83.0 2020-06-03)) **Short description of error** Blender crashes if I close the render window, while it is still rendering. **Exact steps for others to reproduce the error** 1. Open a scene and start rendering. 2. the rendering window will open showing the render as it progresses. 3. While it is still rendering, close that window. 4. Boom... crash.
Author
Added subscriber: @lunarbase
Member
Added subscriber: @ankitm
Member
Do you get a crash report afterwards, next time when you open Blender ?
Please save it in a Text Editor and upload the file.
Do you get a crash report afterwards, next time when you open Blender ? Please save it in a Text Editor and upload the file.
Added subscriber: @dark999
GPU with 512 MB of VRAM is one hardware configuration not supported by Blender
GPU with 512 MB of VRAM is one hardware configuration not supported by Blender ![Blender_Requirement_20200619.png](https://archive.blender.org/developer/F8647868/Blender_Requirement_20200619.png)
Member
Ankit Meel self-assigned this 2020-06-27 18:15:13 +02:00
Member
Right, Thanks!
https://www.blender.org/download/requirements/
> GPU with 512 MB of VRAM is one hardware configuration not supported by Blender Right, Thanks! https://www.blender.org/download/requirements/
Author
wow. If Blender works and the render works on my computer and the bug is just when you close the window, are you willing to close a bug report that probably affects other users just because my graphics card is not supported?
and worse, dismissing a bug report without even trying to see if the bug happens on a mac with a newer configuration?
this is genius.
I am a long time Maya user, in fact I use it since release 1.
I have tried Blender for the first time today and was impressed by how good the software is.
was.
wow. If Blender works and the render works on my computer and the bug is just when you close the window, are you willing to close a bug report that probably affects other users just because my graphics card is not supported? and worse, dismissing a bug report without even trying to see if the bug happens on a mac with a newer configuration? this is genius. I am a long time Maya user, in fact I use it since release 1. I have tried Blender for the first time today and was impressed by how good the software is. was.
Member
I tried it on macOS 10.14.5, Intel HD 6000, 1.5GB
Default cube > engine cycles> samples: 1 > render image > close the new window while render is going on.
It doesn't crash.
  • Please try 2.90 https://builder.blender.org/download/, and upload the crash report in a text file.
  • Also does it happen on simpler scenes, like the one I described ? If not share the simplified blend file with us for testing.
    If that doesn't crash on another Catalina, it can be closed it as out of memory error.
I tried it on macOS 10.14.5, Intel HD 6000, 1.5GB Default cube > engine cycles> samples: 1 > render image > close the new window while render is going on. It doesn't crash. > Do you get a crash report afterwards, next time when you open Blender ? > Please save it in a Text Editor and upload the file. - Please try 2.90 https://builder.blender.org/download/, and upload the crash report in a text file. - Also does it happen on simpler scenes, like the one I described ? If not share the *simplified* blend file with us for testing. If that doesn't crash on another Catalina, it can be closed it as out of memory error.
Member
Changed status from 'Archived' to: 'Needs User Info'
Ankit Meel removed their assignment 2020-06-27 19:22:38 +02:00
Member
As a workaround, you may disable rendering in a new window - x, and make a new main window manually ({nav Window menu > New (main) Window} ) and set it to "Rendering" workspace and toggle between them using {key command `}.
As a workaround, you may disable rendering in a new window - [x], and make a new main window manually ({nav Window menu > New (main) Window} ) and set it to "Rendering" workspace and toggle between them using {key command `}. - [x]: https://blender.stackexchange.com/a/164975
Member
Added subscriber: @lichtwerk
Member
@lunarbase: does the above workaround work for you?
Added subscriber: @ideasman42
Campbell Barton self-assigned this 2020-07-29 05:34:20 +02:00
More than a week without reply or activity.
Due to the policy of the tracker closing for until required info/data are provided.
If the problem persists please open a new report with the required information.
More than a week without reply or activity. Due to the policy of the tracker closing for until required info/data are provided. If the problem persists please open a new report with the required information.
5 Participants
Reference: blender/blender#78362
