OIDN Viewport Denoiser start sample behaviour differs depending on number of viewport samples #78370
5 Participants
Reference: blender/blender#78370
Operating system: Darwin-19.5.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 5500M OpenGL Engine ATI Technologies Inc. 4.1 ATI-3.9.15
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-25 21:53, hash:
62aa103d48
Worked: n.a.
When viewport samples is set to 1 and start sample to 1, you immediately get a denoised image. When viewport samples is set to anything larger than 1 and start sample to 1, you get noisy images while the first 2 samples are being rendered, and then the first denoised image appears while the third sample is rendered. Setting the start sample to 0 does directly give a denoised image.
Cycles rendered view, viewport denoising set to OIDN
Viewport samples 1, denoising start sample 1: denoised image appears directly
Viewport samples >1, denoising start sample 1: denoised image appears when the third sample is being rendered
Viewport samples 1, denoising start sample 0: denoised image appears directly
Added subscriber: @blenderrocket
Added subscriber: @YAFU
This that I am going to comment has to do more than anything with the title of the entry, for me not to open a new report because the problems may be related. Here I commented something about it:
https://developer.blender.org/rB669befdfbe487f76c65f54e3da0013d140d56893#270857
The point is that depending on the Viewport Samples and Start Sample settings, denoising in viewport may not run under certain circumstances, not only with OIDN but also with Optix denoiser. I think this could be due to render speed in viewport according to the scene, so people with different hardware could get different behaviors and perhaps not everyone can reproduce the problem in the same way. Anyway it is not clear to me exactly when the problem occurs.
Here is a .blend file:
Bug 2.9-viewport denoising volumetric world vs no volumetric world.blend
On my machine (i7-3770 CPU), by default scene does not run denoiser in viewport. If in the scene with the same settings you in World tab select Volumetric World instead of World, then rendering in viewport is slower and when it reach Start Sample then denoiser it is executed and work this time.
Added subscriber: @iss
I can confirm this, but I am not sure if this is bug or some limitation.
Added subscribers: @brecht, @ZedDB
@brecht bug or not?
Added subscriber: @lichtwerk
Not totally sure if I am reading this report correctly.
Is this the same (or similar) then {#79680}?
In that case it should be fixed already with
58a457da3d
.Could you guys check if this is still an issue in a fresh build from https://builder.blender.org/download/?
If this is still the case, please confirm it (if you can), does not have to be classified as bug (but confirming helps already).
It works as expected now, this bug can be closed, thanks.
Changed status from 'Needs User Info' to: 'Resolved'
