Mirroring in object mode screws up normals #78512
5 Participants
Reference: blender/blender#78512
Operating system: Windows 10
Graphics card: RX 480
Broken: 2.83
Mirroring objects in edit mode inverts normals. This does not happen with Mirror modifier and mirroring in edit mode.
Select an object
Ctrl M -> X, Y or Z
1st: Ctrl M (edit mode)
2nd: Ctrl M on instances (object mode)
3rd: Ctrl M on single users (object mode)
4th: Using mirror modifier
5th: Mirroring the object using mirror modifier (without applying, object mode)
6th: Applied mirror and deleted unwanted parts
I did a bunch of tests regarding mirroring.
What I found is that when you mirror objects using the Mirror Modifier and in edit mode, they cause no problems in other software
The problem is when you Ctrl M in object mode.
After doing so, you don't get the indication of inverted normals in Blender's viewport (unlike edit mode).
Nothing seem to fix it. Applying transforms, recalculating normals, triangulization, export settings, etc etc.
This is the same file as in the first screenshot. Face orientation is on, meaning the purples represent normals pointing outwards.
Despite not having any bad indication in Blender, when you import it as fbx and import it to the majority of other software, it displays as flipped normals
Displayed Flipped: Substance Painter, Unreal, Marmoset Toolbag 3
Displayed normally: Unity
#92366 was marked as duplicate of this issue
Added subscriber: @joaokalva
Added subscriber: @iss
I can not reproduce this. Can you provide example file?
You can go to edit mode select all geometry and flip normals as workaround.
In the Gif I create a new project, add suzanne, activate face orientation.
Mirroring with Ctrl-M in edit mode gives the correct feedback.
Then I add another suzanne, and this time I am mirroring in object mode.
Doing so does not give me the feedback that it has flipped normals.
Mirrored Objects.blend
This is the .blend of the previous tests
Added subscriber: @Diogo_Valadares
maybe a duplicate https://developer.blender.org/T37652
Thanks for explanation, I get what the problem is now.
This is correct. Mirroring in object mode will only apply scale of -1 in mirroed axis. Normals are not flipped. During export object scale is applied though. You can do it manually in menu Object > Apply > Scale
This is working as intended and there fore not considered a bug.
I am not familiar with workflows here but please look at one of the community websites: https://www.blender.org/community/
If you think this should be changed, please use other channels: https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
For more information on why this isn't considered a bug, visit: https://wiki.blender.org/wiki/Reference/Not_a_bug
Closed as duplicate of #37652
Allow me to disagree, but I don't think this is expected behavior.
Applying transformation doesn't fix the issue, and if I don't happen to have a slight technical background, there's no way I can know what is going on because I get no information about the problem.
In my experience, since I have started using Substance Painter 1.5 years ago this was a problem and I'd never understand why until I decided to spend these 6 hours trying to tackle the problem.
This was not exclusive to me.
https://polycount.com/discussion/220942/blender-flipping-normals-when-mirroring-objects/
"It's very annoying, but that is just how that operator works"
"It's a long standing and very annoying feature"
https://www.facebook.com/groups/265386433819253/?post_id=1137569739934247&comment_id=1138373413187213
Other people also reported how annoying it was to work around this and how inconsistent blender was when this problem arrived
My suggestion is not to fix anything, but to simply remove Ctrl M from object mode to avoid confusion that can be very annoying to deal with
I would agree with you, but my point is that we use this bugtracker strictly to fix unintended functionality of code (bugs). Please use following link to provide feedback or suggestions https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
Added subscribers: @de_bugger, @lichtwerk
