Knife Selection tool inaccessible through keyboard shortcut #78540
Closed
opened 2020-07-02 16:56:52 +02:00 by Sundaram Ramaswamy · 22 comments
Operating system: macOS 10.15.5 (Catalina)
Graphics card: Radeon Pro 560X 4 GB and Intel UHD Graphics 630 1536 MB
Broken: 2.83.1, branch: master, commit date: 2020-06-25 09:47, hash: 8289fc688b3e, type: Release, build date: 2020-06-25, 10:31:24
Worked: 2.79b
Knife Tool, used to cut a mesh in Edit Mode, has an option to affect only the selection. As per the documentation this can be accessed using Shift-K. Pressing Shift-K doesn't give us the tool.
However, this is can be accessed via the Toolbar UI. Click on Knife icon, then click on check box Only Selected and we get the desired tool. Its keyboard shortcut (Shift-K) doesn't launch this tool though.
  • Launch Blender 2.83.1
  • Select default cube object
  • Enter Edit Mode (Tab)
  • Enter face selection mode (3)
  • Select a single face
  • Press Shift-K
No Knife Select tool as per the documentation .
**System Information** Operating system: macOS 10.15.5 (Catalina) Graphics card: Radeon Pro 560X 4 GB and Intel UHD Graphics 630 1536 MB **Blender Version** Broken: 2.83.1, branch: master, commit date: 2020-06-25 09:47, hash: 8289fc688b3e, type: Release, build date: 2020-06-25, 10:31:24 Worked: 2.79b **Short description of error** *Knife Tool*, used to cut a mesh in Edit Mode, has an option to affect only the selection. As [per the documentation ](https://docs.blender.org/manual/en/2.83/modeling/meshes/tools/knife.html?highlight=knife#options) this can be accessed using **Shift-K**. Pressing **Shift-K** doesn't give us the tool. However, this is can be accessed via the Toolbar UI. Click on Knife icon, then click on check box Only Selected and we get the desired tool. Its keyboard shortcut (**Shift-K**) doesn't launch this tool though. **Exact steps for others to reproduce the error** - Launch Blender 2.83.1 - Select default cube object - Enter Edit Mode (Tab) - Enter face selection mode (3) - Select a single face - Press Shift-K No Knife Select tool as [per the documentation ](https://docs.blender.org/manual/en/2.83/modeling/meshes/tools/knife.html?highlight=knife#knife-tool).
Added subscriber: @legends2k
Added subscriber: @sharaths21312
Sharath self-assigned this 2020-07-02 17:35:23 +02:00
The keyboard shortcut is K, not shift+K. The docs do appear to be wrong.
This issue was referenced by 6846
Member
Changed status from 'Archived' to: 'Resolved'
@sharaths21312 Shortcut K is for Knife Tool, Shift-K is for knife tool that operates on current selection only. This bug is for the latter, not former. I think you are mistaken; please check the documentation for the nuance. K continues to work for the knife tool that cuts the geometry (all of it, irrespective of selection), while the bug is for knife tool that needs to operate only on the selection (Shift-K).
@Blendify Please don't change the documentation. This is not about the vanilla Knife Tool that works with K. The documentation is actually right; older versions of Blender used to work with Shift-K for the knife tool that operates only on the current selection.
> In #78540#971623, @sharaths21312 wrote: > The keyboard shortcut is K, not shift+K. The docs do appear to be wrong. @sharaths21312 Shortcut K is for Knife Tool, Shift-K is for knife tool that operates on current selection only. This bug is for the latter, not former. I think you are mistaken; please check the documentation for the nuance. K continues to work for the knife tool that cuts the geometry (all of it, irrespective of selection), while the bug is for knife tool that needs to operate only on the selection (Shift-K). @Blendify Please don't change the documentation. This is not about the vanilla Knife Tool that works with K. The documentation is actually right; older versions of Blender used to work with Shift-K for the **knife tool that operates only on the current selection**.
Added subscriber: @Blendify
@Blendify How do I reopen this issue? This seems to have been erroneously resolved.
Trying out K and Shift-K in 2.79b with some faces selected clearly shows the difference in behaviour between the two tools.
@Blendify How do I reopen this issue? This seems to have been erroneously resolved. Trying out K and Shift-K in 2.79b with some faces selected clearly shows the difference in behaviour between the two tools.
Member
Changed status from 'Resolved' to: 'Needs Triage'
Sharath was unassigned by Sundaram Ramaswamy 2020-07-02 23:14:15 +02:00
Removed subscriber: @sharaths21312
Member
Member
Aaron Carlisle self-assigned this 2020-07-03 01:33:49 +02:00
Member
Added subscribers: @WilliamReynish, @ideasman42
Member
Looked into the code and this is possible with the built-in 2.7x keymap. This patch brings it back to work in both modes:
P1503: (An Untitled Masterwork)
diff --git a/release/scripts/presets/keyconfig/keymap_data/blender_default.py b/release/scripts/presets/keyconfig/keymap_data/blender_default.py
index 4b037f209bb..ce88a1eb074 100644
--- a/release/scripts/presets/keyconfig/keymap_data/blender_default.py
+++ b/release/scripts/presets/keyconfig/keymap_data/blender_default.py
@@ -4508,6 +4508,8 @@ def km_mesh(params):
         ("mesh.dissolve_mode", {"type": 'DEL', "value": 'PRESS', "ctrl": True}, None),
         ("mesh.knife_tool", {"type": 'K', "value": 'PRESS'},
          {"properties": [("use_occlude_geometry", True), ("only_selected", False)]}),
+        ("mesh.knife_tool", {"type": 'K', "value": 'PRESS', "shift": True},
+         {"properties": [("use_occlude_geometry", False), ("only_selected", True)]}),
         ("object.vertex_parent_set", {"type": 'P', "value": 'PRESS', "ctrl": True}, None),
         # Menus.
         op_menu("VIEW3D_MT_edit_mesh_faces", {"type": 'F', "value": 'PRESS', "ctrl": True}),
@@ -4543,8 +4545,6 @@ def km_mesh(params):
             ("mesh.faces_select_linked_flat", {"type": 'F', "value": 'PRESS', "shift": True, "ctrl": True, "alt": True}, None),
             ("mesh.spin", {"type": 'R', "value": 'PRESS', "alt": True}, None),
             ("mesh.beautify_fill", {"type": 'F', "value": 'PRESS', "shift": True, "alt": True}, None),
-            ("mesh.knife_tool", {"type": 'K', "value": 'PRESS', "shift": True},
-             {"properties": [("use_occlude_geometry", False), ("only_selected", True)]}),
             *_template_items_object_subdivision_set(),
@ideasman42 @WilliamReynish is there are rhyme or reason to the way things are now or is this change okay?
Looked into the code and this is possible with the built-in 2.7x keymap. This patch brings it back to work in both modes: [P1503: (An Untitled Masterwork)](https://archive.blender.org/developer/P1503.txt) ``` diff --git a/release/scripts/presets/keyconfig/keymap_data/blender_default.py b/release/scripts/presets/keyconfig/keymap_data/blender_default.py index 4b037f209bb..ce88a1eb074 100644 --- a/release/scripts/presets/keyconfig/keymap_data/blender_default.py +++ b/release/scripts/presets/keyconfig/keymap_data/blender_default.py @@ -4508,6 +4508,8 @@ def km_mesh(params): ("mesh.dissolve_mode", {"type": 'DEL', "value": 'PRESS', "ctrl": True}, None), ("mesh.knife_tool", {"type": 'K', "value": 'PRESS'}, {"properties": [("use_occlude_geometry", True), ("only_selected", False)]}), + ("mesh.knife_tool", {"type": 'K', "value": 'PRESS', "shift": True}, + {"properties": [("use_occlude_geometry", False), ("only_selected", True)]}), ("object.vertex_parent_set", {"type": 'P', "value": 'PRESS', "ctrl": True}, None), # Menus. op_menu("VIEW3D_MT_edit_mesh_faces", {"type": 'F', "value": 'PRESS', "ctrl": True}), @@ -4543,8 +4545,6 @@ def km_mesh(params): ("mesh.faces_select_linked_flat", {"type": 'F', "value": 'PRESS', "shift": True, "ctrl": True, "alt": True}, None), ("mesh.spin", {"type": 'R', "value": 'PRESS', "alt": True}, None), ("mesh.beautify_fill", {"type": 'F', "value": 'PRESS', "shift": True, "alt": True}, None), - ("mesh.knife_tool", {"type": 'K', "value": 'PRESS', "shift": True}, - {"properties": [("use_occlude_geometry", False), ("only_selected", True)]}), *_template_items_object_subdivision_set(), ]) ``` @ideasman42 @WilliamReynish is there are rhyme or reason to the way things are now or is this change okay?
Member
I updated the manual to reflect the current state in: rBM6847
Member
Member
didnt mean to close this...
Member
Added subscriber: @lichtwerk
Member
Is this a confirmed bug? or something that needs triage? (cant be both I think...)
This issue was referenced by blender/blender@4a289081a5
This issue was referenced by blender/blender@4a289081a584aec8f0b72da350e66fdcc5a8615b
6 Participants
Reference: blender/blender-manual#78540
