UV editor Align operator is unintuitive #78557
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
5 Participants
Reference: blender/blender-manual#78557
Broken: 2.7x, 2.8x
UV editor's Align operator aligns X on Y axis, and Y on X axis.
Open default file
go to the uv editor
select uvs
press shift+W
align X, they will be aligned in the Y axis
Added subscriber: @Gilberto.R
Added subscriber: @ronsn
That is mathematically correct. Align X aligns along the x axis and is the same as
S
->X
->0
.@Gilberto.R For further infos see: https://docs.blender.org/manual/en/2.83/modeling/meshes/uv/editing.html#straighten-align Does that solve your issue, or is the alignment really wrong on your system?
Added subscriber: @mano-wii
I wouldn't say this is a bug. But I agree that the name is a little confusing.
This has been reported before if I'm not mistaken.
Perhaps the best would be to change the name from "Align X" to "Equalize X"?
I'll leave the decision to the
Interface
orDocumentation
team.Align - to put two or more things into a straight line.
The operator says "Align UVs on X axis". So it would mean to put things on the X axis in a straight line. Which is not what it does.
The X axis is horizontal. But the operator will align in a vertical line, and that's not the Y axis either, because it's not centered. So it puts in some line based on the center of selection.
The problem is not the word Align, it's how it was used. Align on X should simply be renamed to "Align vertically" and Align on Y should be renamed to "Align horizontally".
Added subscriber: @iss
As person unfamiliar with this feature I really can't tell what is it's intended funcionality and purpose from documentation, so I guess I will go ahead and conirm this.
UV editor's Align operator says the wrong axis.to UV editor Align operator is unintuitiveChanged status from 'Needs Triage' to: 'Confirmed'
Added subscribers: @JulianEisel, @ideasman42, @Blendify
I agree that the best option here seems to be to rename the operator. Based off https://en.wikipedia.org/wiki/Axis-aligned_object I would expect "X Aligned" UVs to be parallel to the X-axis.
I do not think this is a good idea, I think if two lines were equal they would have the same length.
@ideasman42 @JulianEisel do you have any oposition to switching the behavior of Align X and Align Y?
why not name align vertically/horizontally
