Optix denoising is not working everywhere. #78571
7 Participants
Reference: blender/blender#78571
Operating system:
Linux : 5.6.0-0.bpo.2-amd64 #1 SMP Debian 5.6.14-2~bpo10+1 (2020-06-09) x86_64 GNU/Linux
Nvidia : Driver Version: 440.82 CUDA Version: 10.2
CPU :AMD Athlon 2 with 8Gio RAM
GPU: Nvidia Gtx 750 2Gio VRAM
Broken: 2.90 dev master
The Nvidia optix denoising does not work on the entire frame. It just makes a circle denoised; the rest is denoised strangely. This results in a not efficient render.
Open Blender 2.90 master with startup config. In settings, change to device Optix, then in the scene, go into Cycles). Replace the cube by a plane. Add a material to the plane with 0.2 Roughness. Then remove the light and put the camera near the plane. Then, put the samples to 2 for render and view-port. Activate denoising with optix, and start a render preview in the view-port.
bug.blend
Added subscriber: @Kdaf
Added subscriber: @Gilberto.R
Setting rendering device to Optix is for RTX cards only, Didn't it warn you in the preferences "no compatible gpus found"? yours is GTX, which doesn't fully support it, only the the Optix Denoiser. For using the optix denoiser, go to the preferences you should have your rendering device as CUDA. Ok. Now put cycles as the render engine and set Optix denoiser under the Properties Editor->Denoising->Viewport. turn on the checkbox and change it in the dropdown from open image denoise to Optix Denoise.
The same problem comes with CUDA activated in the settings (not optix) and the Optix denoising enabled. I always have this weird circle of delimitation between two area, one is denoised and the other one is not denoised. You can see the result (CUDA in the settings with the optix denoising enabled) :
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Added subscriber: @volto
hi 2060 super user here i rendered the scene on my gpu and it looks like it isn't working but if you look closely the closer the plane goes to the camera the less noise it has; that's because the optix denoising it's trying to do his best with only 2 samples it can't do much
here i added a lamp to make it look more obvious
Added subscribers: @LukasStockner, @pmoursnv
Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
This isn't an issue with the OptiX denoiser, but the denoising passes generated by Cycles (which are passed on to the OptiX denoiser, but are incorrect, so the OptiX denoiser cannot produce correct results):
kernel_update_denoising_features
are deferred to the next bounce, but in this case the next bounce likely hits the background, it's never updated. @LukasStockner is more familiar with this code I think, maybe he could chime in?I guess the problem here is the heuristic used to determine where along the path to record the normal. Due to the Fresnel effect, the relative weights of the diffuse and specular parts change with viewing angle, so at shallow angles the code treats the surface as specular.
This is a known limitation, but I have no idea how to avoid it - we need to set the threshold somewhere. One approach would be to blend it or jitter the threshold, but that results in noisy normal/albedo passes. That causes problems with the NLM denoiser, maybe if Optix/OIDN is more robust to noisy feature passes we could enable it for them.
AFAIK both OptiX/OIDN need noise-free normal/albedo passes too (I know for sure for OptiX). In this case the best solution I can think of is to use the OptiX denoiser with only the color pass as input (so to not confuse it with that albedo/normal data). That's currently only possible to select for final renders though (in the render layer properties), not for viewport denoising (which always uses color+albedo).
Added subscriber: @franMarz
Added subscriber: @YAFU
