Errors thrown by read_homefile api function #78601
6 Participants
Reference: blender/blender#78601
Operating system: Windows 10
Graphics card: GTX 1050 TI MaxQ
Broken: 2.83, 2.83.1, -cad98923d006-
Worked: 2.82
There are errors shown in the system console when running the python command: 'bpy.ops.wm.read_homefile(use_empty=True)'
This might not seem big of an issue, but when running unittests for a plugin that gunks up the test output and makes spotting issues very hard.
Simply run the following commands by loading the attached script file in blender:
(no .blend file needed, this error occurs in a clean blender environment)
script.py
Added subscriber: @Tarcontar
Errors thrown by reading homefile api functionto Errors thrown by read_homefile api functionAdded subscriber: @iss
I can't reproduce this issue.
Can you verify this happens with stock build/install of Blender?
Hi,
just checked again:
2.82 stock -> no issues
2.83 stock -> issue
2.83.1 stock -> issue
2.90 -> issue
The script runs, the view layout is set back to the standard view after opening blender, but the system console contains the mentioned errors.
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Hi,
any updates on this issue?
Regards
Tarcontar
We need developer to reproduce this issue. I can't really pass this to anybody since I have no idea what causes this on your setup but not mine. I guess I could have added a project so there is higher chance this will be looked at by somebody who knows what could go on here.
My github project team member also gets these errors on his system and even our travis CI build shows them:
https://travis-ci.org/github/OpenSAGE/OpenSAGE.BlenderPlugin/jobs/710085672
Added subscriber: @mont29
Does this happen if you start blender with
--factory-startup
?Hi,
we already start it with --factory-startup, but they also show if I remove that.
Changed status from 'Needs Developer To Reproduce' to: 'Needs User Info'
Cannot reproduce that here, further more there is no
Dots Stroke
material in factory startup blender, so... think we'll need more info here.Added subscriber: @feliwir
Hello,
I'm the fellow programmer of @Tarcontar and i get the issues aswell on Linux & Windows.
Our travis CI does a fresh install of Blender before running the tests, so the issue is not related to some customized settings in my opinion.
Yes, but what is your tools doing before calling this function? This error means that some data-blocks has invalid user count, so need to know how/what happens.
Added subscriber: @ideasman42
Please include a blend file and simple script to redo this issue.
Hi,
i attached a script.py file above, a .blend is not needed, since this works with a clean blender environment.
Simply open blender, load the script, run it and view the console.
Tested with 2.90 branch:
blender --factory-startup
script.py
script.py
.There are no errors in the console.
Please test these steps to let us know if they work for you or not.
just tested again with current 2.90 beta:
and 2.91.0 alpha:
both tested with and without '--factory-startup'
here is a problem-step-recorder record, maybe that helps:
steps to reproduce.zip
I can confirm that this is still happening
Tested it on another pc (no blender ever installed) with blender 2.83.4 portable and also got the errors in console.
Still cannot reproduce... Note that those 'steps to reproduce' are kinda useless for us, being on linux...
I can redo this error in
blender-v2.83-release
branch (04345dcf897c9404a16588a6bc0f99e26ec39df2
).But not in
blender-v2.90-release
(c5519d4b6f7f83bd8dab8491b8615512b65686ac
).So as far as I can tell this has been fixed, although it's not impossible the issue somehow still exists on windows.
This issue was referenced by
76f513f6dc
Changed status from 'Needs User Info' to: 'Resolved'
The issue still persists for me on latest 2.90 release (Windows) and also on our travis pipeline (Linux).
See: https://travis-ci.org/github/OpenSAGE/OpenSAGE.BlenderPlugin/jobs/723174394
