Looop Tools does not load into Add Menu when trying to add it from Addons #78644
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#78644
Operating system: Windows-10-10.0.17134-SP0 64 Bits
Graphics card: Intel(R) HD Graphics 4600 Intel 4.3.0 - Build 20.19.15.5070
Broken: version: 2.83.1, branch: master, commit date: 2020-06-25 09:47, hash:
blender/blender@8289fc688b
Addon Information
Name: LoopTools (4, 7, 3)
Author: Bart Crouch, Vladimir Spivak (cwolf3d)
Added subscriber: @bfarber2011
Added subscriber: @rjg
This report does not contain all the requested information, which are required for us to investigate the issue. The LoopTools should be available in the sidebar (shortcut: N) when in edit mode, not in the add menu. Perhaps you're looking for the Extra Objects add-on for curves?
If you're having trouble using Blender, please post a question on [Blender's StackExchange ]], https:*blenderartists.org/ , on the https:*blender.chat/home or one of the other [ https:*www.blender.org/community/ | community websites . The bug tracker is not meant for user support.
In case you believe that you've found a bug, please read [this guide ]] and submit a new report throughHelp > Report a bugin Blender. [ https:*blender.stackexchange.com/questions/1377/best-place-to-put-bug-reports/173685#173685 | This guide may help you write a bug report that allows us to fix your problem. Be sure to provide system information (operating system, GPU, driver version), Blender version, a short and precise description of the issue, step by step instructions to reproduce it and, if relevant, a .blend file that showcases the problem.
