Lattice objects evaluation is not properly decoupled when they share the same Lattice obdata. #78650
6 Participants
Reference: blender/blender#78650
Operating system: Ubuntu 20.04 Linux-5.4.0-39-generic-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 435.21
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-07-04 15:31, hash:
464aaf2701
Worked: Never
Open the file below and see how scaling one bone from one of the armature affects both lattice objects, which are sharing the same obdata.
#78650.blend
original report:
So I have a model of book page with lattice modifier for blending corners. Then using Library Override, Lattice modifier gets object from one and second linked blocks, constantly jumping over each other.
2020-07-05 21-25-55.mp4
Library Override Modifer Test.zip
PS. I post this information here https://developer.blender.org/T70319, but it is not been resolved for my case, so I decided to open new bug report
Added subscriber: @crantisz
#86740 was marked as duplicate of this issue
#84503 was marked as duplicate of this issue
Added subscriber: @mano-wii
I can confirm the problem in Release Build.
The file could be further simplified so that the real problem is revealed more clearly.
But I will go ahead and conirm this.
Simplified version
lattice modifier.zip
Lattice modifier driven by bone scale
2020-07-09 10-51-24.mp4
Added subscriber: @mont29
Eeeeh, issue has nothing to do with overrides in fact, you can reproduce similar case by duplicating the collection in original file, and assigning the same Lattice obdata to both lattice objects:
#78650.blend
So this is an evaluation issue, lattice obdata shared between objects are not properly decoupled for some reason.
Library Override: driven modifiers don't work properlyto Lattice objects evaluation is not properly decoupled when they share the same Lattice obdata.@crantisz A workaround for now is to also create overrides of those lattice obdata (Shift-click on the 'make local' icon to the right of the ID selector in the ObData properties)
Added subscriber: @sozap
Added subscriber: @Mets
Added subscriber: @fsiddi
This will be a big problemo for the Studio, as the forest creatures of Sprite Fright will use (and already are using) plenty of lattices, and will be (and already are) duplicated plenty of times.
The current workarounds would either involve the animators individually shift-clicking every lattice(lattices which are thoroughly hidden) every time they duplicate a creature's collection, or I would need to distribute some nasty Python script that does it for them automatically - which I was told by @fsiddi is strictly forbidden, since this kind of stuff should be fixed properly. Also, who knows what kind of issues we would run into by making all those object datas single user.
Which basically translates to this being a showstopper for Sprite Fright! 😱 For now the animators were told to simply not use lattices while animating. Would be good to have this bumped on someone's priority list, or to get an ETA on it so we can plan and set expectations accordingly.
@mont29 I can't reproduce it with your no-overrides-used file, even when I try it with a 2.90 or 2.91 release. The simplified file from @crantisz does show the problem here on my machine.
Here is a (hopefully) simpler file to see the issue:
lattice_boy_instanced.blend
You just need to move the active bone and you should immediately see the problem.
This issue was referenced by
3681a619de
