Blender closing after rendering several PNGs from animation sequence #78769
Reference: blender/blender#78769
{F8680846}System Information
Graphics card: GeForce GTX 1650/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 451.48
i5 2nd Gen CPU 3.3Ghz
12GB DDR3 RAM
Broken: version: 2.83.1, branch: master, commit date: 2020-06-25 09:47, hash:
8289fc688b
Worked: 2.83.1 installed after first encountering this problem in 2.83.0 a few days ago. Previously no issues with 2.83.0/2.79/2.79b
Blender shuts down after rendering anywhere from 5-30 frames
Error : EXCEPTION_ACCESS_VIOLATION
Address : 0x0000000141D1C658
This has only started to occur in the last week with 2.79/2.79b/2.83.0 all running successfully prior to then.
GPU is approximately 1 month old with latest drivers installed.
Latest available Blender 2..83.1 installed yesterday after removing all previous versions. This appeared to solve the problem for a short time but problems returned.
Non-default add-ons were disabled for no change.
Win7 User Account Control settings switched to lower settings including "off" for no change.
CTRL F12. Blender closes after successfully rendering some image files.
Sample file attached
What further steps should I take to find the cause of my problems?
Added subscriber: @hc
Added subscriber: @VincentBlankfield
Could you check if the problem happens with [2.83.2 ]] or [ https:*builder.blender.org/download/ | 2.90 Alpha daily build . There has been an issue of cycles animation rendering randomly crashing, that may or may not be the cause of this. The problem was fixed in those versions.
2.83.2 seems to have improved things so far after a couple of hours working with it. I've got a fair bit of rendering to do in next couple of days so that should give a solid workout.
From my initial report the only way I could solve my problem using 2.83.1 was to render with CPU only. Factory restore, new GPU drivers and a number of other things did nothing. Not sure if that information helps you going forward with future maintenance releases, Some sort of conflict with this GPU or its drivers I'm guessing
Added subscriber: @brecht
Changed status from 'Needs User Info' to: 'Resolved'
I'll assume this is fixed in 2.83.2 then, if it still happens we can reopen the report.
Thank you
