Background Image Transform Widget does NOT respect LOCKED transform channels #78771
2 Participants
Reference: blender/blender#78771
Operating system: Windows-8.1-6.3.9600-SP0 64 Bits
Graphics card: GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.66
Broken: version: 2.83.0, branch: master, commit date: 2020-06-03 14:38, hash:
211b6c29f7
Worked: (Unknown)
Hi Blender Dev Team, I've encountered a fairly troublesome bug while working with architectural blueprints as background images. The yellow transform widget that appears when hovering over a background or reference image can be manipulated even when the image's location, rotation, and scale is LOCKED in the item transform tab.
Moreover, setting keyframes for LocRotScale as well as for the Image Empty's "Size" property, cannot protect against the image being accidentally moved, only against being resized. This is due to the yellow transform widget keeping the image's origin stationary while applying the transformation. This bug results in extremely dangerous and unpredictable behavior, since crucial reference images can now be incorrectly scaled or re-positioned without warning.
(As a side note, the size property in the Object Data Properties tab seems to not update after scaling the yellow widget until AFTER you click on something else and then back on the image again either in the 3D viewport or in the Outliner... but that small issue with the dependency graph is not really a problem, just unusual.)
Thanks so much for looking into this. I would also grateful to know if there is a way to disable the yellow corner widget as a temporary solution to avoid any accidental resizing.
Best regards,
Adam Janz
Added subscriber: @AdamJanz
I thank the Lord Jesus Christ for showing me a temporary workaround:
Deselect "Active Object" under the "Viewport Gizmos" options. That will at least prevent someone from accidentally moving or resizing their reference image while its transform channels are locked, and is a viable workaround while we await a fix from the devs. Thanks and have a good day everyone.
Added subscriber: @mano-wii
You can disable the image gizmo:
The image gizmo does not affect the object transform values. It represents other properties.
Thanks for the report, but the issue reported here is a request for modified/improved behavior and not a bug in current behavior. Closing as this bug tracker is only for bugs and errors.
For user requests and feedback, please use other channels: https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
For more information on why this isn't considered a bug, visit: https://wiki.blender.org/wiki/Reference/Not_a_bug
Thanks so much Germano for that info. I had not seen that checkbox before, so that's very helpful. Yes, I guess I could add this in the feature requests. However, since the image gizmo does not "technically" affect the object transform values, but the end result of using it DOES affect the object's perceived transform, such contradictory behavior would normally be considered a bug to most users. However, I'm glad there is more than one workaround to disable it from getting in the way. Thanks again for your help!
