Grease pencil cutter tool doesn't reliably terminate lines where they intersect #78786
5 Participants
Reference: blender/blender#78786
Operating system: Darwin-19.3.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 580 OpenGL Engine ATI Technologies Inc. 4.1 ATI-3.5.5
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-28 15:13, hash:
b21ba5e579
Load the attached blend file.
Use the cutter to drag around the green area of the top line. A new point is added, but the line's terminated too early. Leaving a lump on the 'cutter side' of the intersection.
Undo. And drag the cutter tool around the red area of the bottom line. A new point is added, but the line's terminated too late. Leaving a small gap on the other side of the intersection.
Expected behaviour: The cutter tool adds a new point exactly on the intersection with the second line and deletes points up to that new point.
cutterproblem.blend
Added subscriber: @info-27
Added subscribers: @filedescriptor, @antoniov
This actually is a limitation of the algorithm used. If you look at your example file, there isn't geometry near of the intersection. The algorithm needs some point more or less near of cut position. If you subdivide and add a point, you will see the cutter works better.
Thanks for your report, but as now we haven't time and resources to work in the improvement of this tool, we are going to consider as a Know Issue that could be improved in the future with a better cutter algorithm.
@filedescriptor I think some of your algorithms could be used here.
@antoniov Indeed. This can be solved with the boolean algorithms. For now, it is a limitation.
Added subscriber: @iss
Will confirm as this is classified as known issue.
Added subscriber: @jack.herbert
