GPencil: Texture Image Alpha pass through grease pencil strokes #78795
13 Participants
Reference: blender/blender#78795
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.87
Broken: version: 2.83.1, branch: master, commit date: 2020-06-25 09:47, hash:
8289fc688b
Context: Using texture image to make some kind of 2d fur on top of a GPencil Object
The Image Texture used to make some fur is mostly transparent and the brush used to make the colored part is a texture paint brush with Cloud Mask (it was made entirely in Blender with Blender tools).
When on top of the GPencil object, the part of the Image Texture that is only half transparent(between 99%-1% transparent), makes the GPencil color disappear, even when moving the center point behind the one of the fur images.
On the contrary, when on top of another Image Texture (imported to be used as camera mapping), the Image Texture of the fur doesn't impact the transparency of that one.
Notice that the Image texture boundary, even from the imported one, has problems with clipping and always makes a white line appear.
Thanks for your help!
bug_alpha.blend
Added subscriber: @Pullup
#87366 was marked as duplicate of this issue
Added subscriber: @mano-wii
I'm struggling to understand the role of each object to the descripition of the problem.
A simplified file is highly recommended.
But I notice that there is something strange about the material of the
Fur_Image
mesh object.I am not very familiar with this area. It may not be a good practice to mix transparent meshes with Grease Pencil objects.
I'm marking the
team to take a look.Texture Image Alpha pass through Grease Pencilto GPencil: Texture Image Alpha pass through grease pencil strokesAdded subscribers: @fclem, @antoniov
@fclem Could you take a look?
This is the issue of compositing EEVEE foreground elements with Gpencil in the background. the AA patern does not match perfectly and uncover the scene background.
Workaround: If you disable EEVEE AntiAliasing and GPencil AntiAliasing it fixes the issue but you loose the antialiasing. Render to twice the resolution and downsample in post processing to reduce antialiasing.
I would consider this known limitation as we don't have any planned fix for this.
Ok thanks for the infos and workaround @fclem
Further notes :
EEVEE with material blend mode
Alpha Blend
(default withimport image as plane
) has different problem : Texture mesh appears behind the GPencil object.Cycles, The alpha completely holdout the Grease pencil
Added subscriber: @jack.herbert
Like the OP, I also noticed this whilst mixing Image Textures and GPencil. Then when trying to reproduce it with the smallest amount of steps, I realised that it doesn't just affect Image Textures but anything that passes in front of a GPencil object apart from other GPencil objects.
Thought I'd post this screenshot to illustrate the problem a bit more clearly. It's black GP filled square, between two 3D meshes, a blue plane and a red UV sphere (both with Emission shaders):
So I understand there's no plan to fix this cos it might not be that simple, but doesn't that seriously limit possibilities if GPencil objects can never be behind 3D meshes? (at least without having to render at twice the size (btw thanks for that workaround))
Added subscriber: @adrianth
I agree with Kevin'g comment above - this issue seems like a pretty serious limitation, as the one significant competitive advantage Blender Grease Pencil has over 2D animation software is the ability to combine 3D elements in a 2D scene; using textured 3D meshes with alpha transparency is a very powerful tool. I understand if this issue is not high priority and might not get fixed in the near future, but in my opinion it should not be classified as known limitation. Please let me know if I'm missing something. I would appreciate if someone from the dev team can post a point of view on this.
I found a slightly better workaround for the anti-aliasing issue. If you put the Gpencil objects and 3d objects on two different View Layers then put them back together in the compositor with a Z Combine node (enable Use Alpha and disable Anti-Alias Z), you will still need to set EEVEE's filter size to 0, but you can keep the Grease Pencial anti-aliasing on. So not perfect but in some cases it might be enough.
@adrianth I think that's not exactly the same problem, in your case you just need to switch Alpha Blend to Alpha Hashed in the material settings.
Added subscriber: @CarstenJaeckel
@jack.herbert : Yes, that works, but it is very noisy instead of Alpha Blend.
Added subscriber: @MarcelLegindi
Should help? http://diglib.eg.org/bitstream/handle/10.2312/EGGH.EGGH08.033-040/033-040.pdf?sequence=1
Added subscriber: @tezaron
I think I have a similar issue to the ones described above. I created a 2D cut-out rig using multiple grease pencil objects. Issue I have is that the alpha of the textured stroke seems to holdout on the grease pencil objects behind them in 3D space in some places.
I have tried some the workarounds described above but have not had any satisfactory results, if anyone has any other workaround suggestions it would be appreciated.
I understand this is currently no plan to fix this, but it is quite a big limitation for us when trying to replace our current 2D anmation software (celaction) with blender.
Thanks :D
by any chance, will this be addressed in GP 3?
New to grease pencil here, but I think I have something that looks similar.
Drawing these strokes with an image background underneath produces these white outlines. They are pretty thin, but become really pronounced when zooming out.
If I go to world properties -> viewport display and change the colour, the outline changes to that same colour.
I also have an issue of really fine strokes fading away when zoomed out on a regular white background, and it seems to be the same issue - because the white outline of my strokes overpower the thin lines when zoomed out.
