Modification of Startup addon for Generate Torus mesh : section angle and twist feature added #78948
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#78948
Hello,
i have modified the Startup addon for Generate Torus mesh.
for define the section angle and section twist.
see the demo video here : https://twitter.com/aiekick/status/1283182645158064129
i think this code can be usefull, but not sure if its required by community.
this is what i wanted to do when i created a simple torus.
i found the default addon not usefull in some cases
add_mesh_torus.zip
Added subscriber: @AieKick
Completed for have two types of uv map.
add_mesh_torus.zip
Added subscriber: @mont29
Thanks for the patch, but please submit it through the proper review/diff process (https://developer.blender.org/differential/diff/create/)
ok, i will.
I never done that before :)
done here : https://developer.blender.org/differential/diff/34826/
Not sure to understand why this ticket was closed.
This modification is rejected or maybe can i do some modifications ?
i thinkc this script fill a gap of feature lack for the otrus script. but maybe there is something i not understand ?
all guys i know who are using this modified script found it usefull.
@AieKick afaict, you only created a diff, you need to create a revision from this diff now, and get it reviewed (top part of the diff page). Discussion about your changes will then happen in the diff, not in this report.
ok thanks for thsi information
ok its done : https://developer.blender.org/D11761
i have abandonned the last diff (not found a button for modifiy or delete it) because i have updated the code regarding the last torus startup script i have in blender 1.93
not sure about what reviewer or subscriber to use.
same for the repositery to use
thanks
