"ID Data" → "Make Single User" in Outliner for Curve animation data crashes Blender #79187
Reference: blender/blender#79187
Graphics card: Intel(R) Iris(R) Plus Graphics 640 Intel 4.5.0 - Build 26.20.100.7639
Broken: version: 2.83.0 (release), 2.83.3, branch: master, commit date: 2020-07-22 06:01, hash:
353e5bd749
Broken: 2.90 release branch @
ee98dc8d0f
Worked: 2.80, 2.82
Making Curve animation data single-user crashes Blender.
(original report: Linking animation data on curves like keyframed Bevel Start and End values permanenly links animation data and I can't unlink it using "Make Single User" in order to offset curve animation in several curves.)
With Blender in factory defaults:
The above gives you this example file:
#79187-linked_curves-mine.blend
BezierCurveAction
in the outliner and select it.(original report: if you go "Make single User" and select "Animation Data", animation is not unlinked. Changing values on one curve changes animation on all other curves previously linked. In attached file, I replicated the issue and compared it with two mesh cubes. Cubes had their animation data linked, and sucessfuly unlinked and offset so they don't have exact same animation. Curves however curves remain linked. F8715762)
Added subscriber: @ReljaTrajkovic
This seems to be by design. "Make Single User" from the "Object" menu only works on object data. It does not recursively go into the object data. This means that it makes the animation data of the Object single-user but not the animation data of the Curve itself.
You can see this in effect by following these steps:
Unfortunately, you can't use the Action Editor to make the Curve animation data single-user either, as that only shows object-level actions. It should be possible via the outliner, but that crashes. I'll see if I can fix that crash, so that there is at least some way to make curve animation single-user.
Can't unlink object animation for linked animation on curvesto "ID Data" → "Make Single User" in Outliner for Curve animation data crashes BlenderAdded subscriber: @dr.sybren
Some developer info:
singleuser_action_cb()
is called withtselem->id
pointing to the curve Object, instead of the curve itself. This means that further code will not be able to properly find the animation data.The function then proceeds to use
iat->id
to find the property that is supposed to be made single-user, butiat->id
points to the Scene.The end result is that IDs are mixed up, and since the Scene doesn't have animation data, Blender segfaults.
There are two problems here. First, this is a known issue with the outliner context menu that I've started fixing for GSoC in #77770 (Outliner Context Menu Cleanup). The first time I tried replicating the crash I realized what the real issue is:
If
BezierCurveAction
is first selected with left click, the parentBezierCurve
object is also selected. Selecting "ID Data" → "Make Single User" from here causes the crash.If
BezierCurveAction
is selected with right click and is the only selected object, the context menu shows like it did in 2.82 with "Make Single User" an immediate option. Running with no objects selected shows that It's a hassle, but a temporary workaround is to ensure that no objects are also selected when running "Make Single User".The issue is that fixing #74332 (driver can't be seen in the driver editor(blender2.82)) required a selection sync to ensure that parent objects are selected. Pre-2.83 a selection on the curve did not select the parent as it should. Because the parent object is selected, the context menu shows additional entries (requiring the ID Data submenu), and the object is passed to
as if it were a curve.However, this is still a bug in that you can cause this to happen pre 2.83. I tested 2.80 with an additional object selected and the result was still a crash.
is called on all selected elements in the outliner. A simple fix for the crash (which I will commit) is to ensure that the id is an action in the callback.For the context menu confusion between 2.82 and 2.83+, I'm experimenting in the gsoc outliner branch today to find a quick solution. if there is a nice and easy solution, I think it could also be applied to 2.90 to fix the context menu showing the wrong entries which has caused confusion elsewhere.
This issue was referenced by
e48054ece4
9cbf43801b
