Scene.Ray_Cast misses/fails against CURVE Objects in multiple cases. #79194
2 Participants
Reference: blender/blender#79194
Graphics card: GeForce GTX 980 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 451.67
Broken: version: 2.90.0 Beta, branch: master, commit date: 2020-07-22 14:02, hash:
0e280b96ca
Worked: None that I know of.
In testing an Addon I'm developing, I came across an issue when Raycasting to CURVE Objects via Scene.Ray_Cast. It appears it will NOT hit the Curve, even if it's displayed as 3D Mesh. Unless I Apply a subSurf Modifier or other modifiers (Bevel/Solidify), then it will detect it. It appears that until it's actually had some sorta of Mesh Modifier applied, it's not considered a Mesh, even though it's displayed as one....
I also hit another issue in 2.9 (build above), where if the CURVE Object is Active, but De-selected, it cannot be raycast against it, until another object has been set active. Then I can RayCast to the Curve once again. In 2.83 (a8441fc90086-windows64) this bug doesn't exist. I can RayCast to the Curve over and over, without issue, if its set active, but de-selected.
Blender_2.9_Scene.Ray_Cast_Bug.blend
TT_Object_Select_Raycast.py
Added subscriber: @mattli911
Here's a GIF showing the same thing in 2.83, except that it doesn't have the 2nd issue with active object, as noted above.
2.83 has no problem selecting back and forth on the Curve if it's active but de-selected. But as I mentioned, raycast fails to hit the Curve still, unless it has a modifier applied.
Added subscriber: @mano-wii
This is a known issue that has already been addressed in #78434 (Support snapping to faces for objects with DispList (Curve, Surface, Metaballs and Text)).
Basically, this was never implemented.
Closed as duplicate of #78434
Ah, ok, great! That would be fixed in 2.91 then i would guess...?
Anyone can propose a patch and proceed with implementation.
In my case there are other items that have priority (#73993)
Yeah that makes sense. Ok. I will just have to wait and see! I don't think there is a good way for me to get around the issue otherwise, in a performant way... using Python.
Unless I can temp. add some modifier/cheapest modifier possible to CURVE objects to get around it, during my Modal operator.
Is not a HUGE issue though, but more of an annoyance/thing I will have to note for now.
Thank you!
For now i am using another workaround, where i just apply a modifier, like Decimate to a CURVE object, which causes Raycast to work, and the modifier does't impact the Object visually in any way, by default.
Definitely not ideal, but "works" in the meantime.
