Objects in front of the selection stay in front in wireframe mode #79204
Reference: blender/blender#79204
Broken: version 2.80+
Worked: version 2.79
In blender 2.79, the wireframe of objects selected or in edit-mode was drawn in front of the wireframe of all other objects in the scene.
In blender 2.80 onwards, this doesn't happen anymore.
Here's a model shown in 2.79b, with my usual theme:
The object in edit mode is behind the objects seen with gray wireframe. But because it is in edit mode, it is drawn in front of the others.
The same is true if the object is in object-mode but selected.
Now compare the same model in 2.8x:
Here the same object is seem in edit-mode. Now it is drawn behind everything else, which creates a noisy, low-contrast appearance, making it hard to see and sometimes hard to edit.
Sometimes it forces me to rotate the view to get other things out of the way (especially if the foreground objects have a lot of detail/geometry).
If you zoom in real close on an area where a foreground object overlaps the selection, snap a screenshot, and then scale or zoom the image, you can see how the foreground object is definitely being drawn in front of the active one:
Bottom line: In my opinion, in a normal view mode like Solid or Lookdev/Material, the selection of course should remain behind everything else (unless changed via its Object properties), but in Wireframe view mode the selected object should appear in front of other stuff.
Perhaps an option is needed the Preferences to force the old 2.79b draw order.
wireframe_in_2_79.blend
classic-look.xml
The original model is probably too big to upload here: https://gitlab.com/VanessaE/my-hypercube-files-big-version-320x320/-/blob/master/mockups-models/Hypercube%20printer%20model%20(320x320%20bed,%20540x510x540%20frame).blend
Added subscriber: @VanessaE
Objects behind the selection appear in front in wireframe modeto Objects in front of the selection stay in front in wireframe modeAdded subscriber: @mano-wii
Thanks for the report,
Can you provide a file (preferably simple) and the theme used so that we can see the problem?
The link provided does not work :\
For future reports, it is good to follow this guide: https://wiki.blender.org/wiki/Process/Bug_Reports
Removing tags like #bf_blender can make the report go unnoticed.
Sorry about that, I renamed the file and forgot to update it here. For something simpler, here's just the five pieces that make up the back corner pictured above:
back corner.blend.zip
And my startup and config/theme files:
vanessa-blender-configs.zip
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
I can't find the custom theme in the attached files.
Custom themes are usually saved as an
XML
file underscripts/presets/interface_theme
.Windows
%APPDATA%\Blender Foundation\Blender\[YOUR VERSION]\scripts\presets\interface_theme\
Mac OSX
/Users/$USER/Library/Application Support/Blender/[YOUR VERSION]/scripts/presets/interface_theme/
$HOME/.config/blender/[YOUR VERSION]/scripts/presets/interface_theme/
But with the file attached, I can now better understand the problem described in the report. (I couldn't understand what was in front or behind in that image).
So basically:
I'm not sure if I can confirm this as a bug because apparently that behavior in blender 2.79 was not intentional.
It also reminds me of #78482 (Selection is covered by unselected geometry in ortho display)
I suggest you report this as feature requests through other channels:: https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
Well I feel like an idiot now :-) Ok, here's the REAL theme file:
classic-look.xml
(It never occurred to me to look into the
/presets/
directory, it's a word I wouldn't associate with a theme file)I'm not sure I agree with how you put it. Sure, if it was unintentional, that by itself is a bug, but that "bug" made things MUCH easier to see, so having "fixed" it makes it more of a regression than a bugfix. Of course, https://xkcd.com/1172/ comes to mind as well...
I edited the description to make the problem easier to understand, but the final decision is for the #eevee_viewport or #user_interface team.
The selection issue is a duplicate of #78482 which has already been confirmed as a TODO.
Added subscriber: @1D_Inc
It seems to be different - #78482 is about closing selection with unselected geometry in edit mode (self-closing), and this one is about draworder in object mode as well.
But the problem with the workflow (workflow issue) is the same - both make it difficult to detect and work with linear / CAD geometry.
Edit mode issue make it hard to work with complex linear objects and this one - with complex linear assemblies, flooding selected/edited object with unnecessary details, makes it harder to percept its real shape.
A comparison: edit mode.
In the right case (2.9) object looks way more complex than it actually is, while in the left case (2.79) there is no problem with its mesh shape recognition, so you can easily detect that it is just a simple extrusion with no imaginary holes.
Basically, when you fall into wireframe mode, you expect to concentrate on your selection, not surrounding objects that already covers your selected object in shaded mode.
Object mode.
A shape of the object in 2.79 is much more recognisable, in 2.9 you have to enter isolation mode to understand how selected element looks like.
In my opinion #78482 is more critical, because object mode at least have an isolation ability that allow somehow to survive through cognitive overload even if it is less comfortable way to work
(if repetitive enabling-disabling isolation mode at every single selection can be called "comfortable" at any point).
Anyway, it would be nice to have a draworder option for cases like this.
A couple of examples
Selected object is almost completely hidden, so you can't recognize it without isolation
object is completely covered with unslected geometry in ortho, so you can't even detect a selection (GIF).
@1D_Inc, it might be a good idea to contact the developers of #eevee_viewport and #user_interface directly to give this task a higher priority.
Well, yes, this is clearly design problem.
I am currently trying to collect all the similar issues considering wireframes in a single tread, to make them nicely observable.
https://devtalk.blender.org/t/blender-2-8-wireframes-discussion/666/373?u=1d_inc
Added subscriber: @APEC
