Blender crash on start-up, EXCEPTION_ACCESS_VIOLATION, OpenGL.3.3 or higher required #79229
Reference: blender/blender#79229
Operating system: Windows 10
Intel Core i7-6700k CPU @ 4.00 GHz
Graphics card:
Broken: All, tested 2.78, 2.79, 2.8, 2.81, latest version on steam, which i assume is 2.83, and the 2.9 beta with the blender_debug_gpu.
Worked: N/A
Program shuts down immediatly after starting up. If starting though cmd i get the exception_access_violation error, if adding opengl32.dll to the directory the error is instead that the graphics card needs to support 3.3 or higher while the version on the pc is 4.6. All drivers are up-to-date. PC has been fully reset in hopes to solve the issue to no avail.
Images of cmd: https:*imgur.com/akjPlBh / https:*imgur.com/PS6oKF0
blender_debug_output.txt Blender_debug_output
blender_debug_output (added opengl32.dll).txt Blender_debug_output (added opengl32.dll)
blender.crash.txt Blender.crash.txt
Added subscriber: @Juliavo
Added subscriber: @rjg
The fact the crash occurs that early and affects even the old versions of Blender, is not a good sign. Have you been experiencing similar issues with other software?
I haven't had this issue with any other software really. This has only been happening with Blender, which is weird because it used to work just fine on the same computer before.
In order to rule out an issue like #72098, please try the following:
Select the energy mode that uses the integrated Intel GPU and save.
If this doesn't change anything, select the Nvidia GPU instead and check if that makes any difference.
I cannot seem to find an option that only uses the Intel GPU. All three of the options show the same graphic cards for both power saving and high performance, i cannot click on them to change them either. I have tried starting the program with all three options but the problem sadly still remains.
Are you able to start Blender in background mode with the factory default settings?
blender.exe
is located).blender.exe --factory-startup --background
When starting Blender in background mode, the errors that appear on the cmd say it's not able to create directories for thumbnails. A screenshot of the console is added below.
It does start Blender though. The creation of the directory may require elevated permissions. Have you tried starting it as administrator (this should only be done for testing purposes, in general it is not recommended)?
The big question is why OpenGL rendering doesn't work properly. Please run the following command in Blender's installation directory to create a system info file.
blender.exe --factory-startup --background --python-expr "import bpy; bpy.ops.wm.sysinfo(filepath=r'%temp%\blender\debug_logs\blender_system_info.txt')" > "%temp%\blender\debug_logs\blender_debug_output.txt" 2>&1
The files should then be located in
C:\Users\julia\AppData\Local\Temp\blender\debug_logs
Ran the command, added the console down below. Not sure if it has anything to do with it, but as soon as i ran the command i got a notification from windows defender asking to scan the file? Clicking on it brought me to a website from Microsoft about 'Blocking at first sight'. https://docs.microsoft.com/en-us/windows/security/threat-protection/microsoft-defender-antivirus/configure-block-at-first-sight-microsoft-defender-antivirus
Edit: Forgot to say but ran Blender as Administrator as well, but it didn't really change anything.
@Juliavo In this specific case it could be because you're using a development build of Blender, combined with the inline Python script that creates a file, which looks suspicious to Windows Defender. It would be interesting though if Windows Defender interferes with Blender on your system in general, because that can also result in a crash (e.g. quarantining files that Blender needs or stopping the process).
The system info file looks fine as far as I can tell, both GPUs get recognized by Blender. However, there are the following two error messages in the debug log:
@Juliavo Can you check if Defender has quarantined any of Blender's files (see "Restore quarantined files" )?
Just tried to start Blender with Windows Defender off, not much changed. It says it's an app that is allowed to go through the Firewall too, i'm not really sure if Defender and Firewall would be the cause of the problem. It probably was indeed just because it's a beta build like you mentioned earlier, figured it was worth a try just in case haha.
No files are shown in the protection history, so i suppose Defender didn't quarantine any of Blender's files.
@Juliavo That rules out the Windows Defender as cause. The firewall wouldn't stop Blender from starting, since it doesn't require any internet connection.
Could you please check if enabling the compatibility mode allows Blender to start with a GUI:
blender.exe
and open the PropertiesThis time instead of a quick flash it showed a fullscreen, white window opening that did close after again, but it did show more than it did before.
Could you please run
blender_debug_gpu.cmd
for 2.90 again, with compatibility mode enabled and uploaded the created files, including the crash log inC:\Users\julia\AppData\Local\Temp
.Ran the command, these are the files that were created.
blender_debug_output.txt With OpenGL32.dll
blender_debug_output (without opengl32.dll).txt Without the .dll
Compatibility mode doesn't seem to have any effect, you can deactivate it.
I would suggest that you install any pending Microsoft updates and then run DISM and SFC to detect and fix potentially broken system files as described in this guide by Microsoft .
Just finished the DISM and SFC, it seems the scans could not find any missing or corrupted files.
I was sure i installed all updates, but suddenly it shows an update for Microsoft defender which quickly disappears after a few seconds as well, again saying i'm fully up-to-date. The update appears and disappears again when i check for updates again. Does that mean my updater is broken?
@Juliavo Since DISM and SFC didn't find any issues, it's probably fine. You'd have to check the update history to see if/why a particular update failed. Since you've already tested with Microsoft Defender disabled, this is unlikely related to the Blender issue.
Unfortunately, I can't see a clear source of the problem with the currently available information. Perhaps somebody else has an idea what the issue might be.
Ah alright. It's such a shame, i was hoping to keep learning and using this program for work. Thank you for taking the time to help me though!
@Juliavo You're welcome.
My general impression, based on the current hardware you're using and the wide range of affected Blender versions, is that this is most likely caused by something on the side of the operating system or drivers.
I have tried running Ccleaner in the hopes that that maybe would get rid of files that could be interfering with Blender, but it doesn't really seem to have done much to help Blender run properly.
@Juliavo I would generally advise against running clean-up / tune-up utilities of any sort. At best they don't break anything. CCleaner in particular has a bad track record.
Ah alright. I've uninstalled it immediatly.
Added subscriber: @iss
If you are unable to run even Blender 2.79, and you say that you was able to run it in the past, it is very unlikely the issue is bug in Blender. My personal advice would be to reinstall OS, if that is possible. if that is not possibility, you can try asking for help on one of the community websites: https://www.blender.org/community/
This tracker is only for reporting reproducible problems, so I will close this report. If you find root of the problem, and you think it is bug in Blender, please open new report.
I have fully deleted all partitions and reinstalled Windows again through a usb, which seemed to do the trick! I hope it stays this way haha. Thank you for the help!
Thanks for letting us know.
