UV: Pivot set to Individual Origins does not work properly w/ sync-select & edge selection #79304
Closed
opened 2020-07-27 04:51:03 +02:00 by Jesse Yurkovich · 8 comments
Graphics card: GeForce GTX 1070 with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 446.14
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-07-25 19:01, hash: 13abacaaf3
Broken: version: 2.79 is also broken
Worked: n/A
It seems like Individual Origins does not work in the UV editor like it does for Meshes. The result of the operation will change significantly if edges share a common neighbhoring edge vs. if they do not.
For context I was attempting to quickly/easily create square UV's for a particular model and ran into the problem.
Baseline setup:
Good Example - Mesh, Scale - X - 0:
Bug Example - UV, Scale - X - 0:
Good Example - Mesh, Scale - X - 0 -- non neighboring:
Good Example - UV, Scale - X - 0 -- non neighboring:
uv-indivorigin.blend
  • Load attached .blend
  • Ensure pivots are set to Individual Origins
  • Try to align edges on X or Y axis in the UV editor for example
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: GeForce GTX 1070 with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 446.14 **Blender Version** Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-07-25 19:01, hash: `13abacaaf3` Broken: version: 2.79 is also broken Worked: n/A **Short description of error** It seems like Individual Origins does not work in the UV editor like it does for Meshes. The result of the operation will change significantly if edges share a common neighbhoring edge vs. if they do not. For context I was attempting to quickly/easily create square UV's for a particular model and ran into the problem. Baseline setup: ![baseline.png](https://archive.blender.org/developer/F8722102/baseline.png) Good Example - Mesh, Scale - X - 0: ![mesh_scale-0.png](https://archive.blender.org/developer/F8722106/mesh_scale-0.png) Bug Example - UV, Scale - X - 0: ![uv_scale-0.png](https://archive.blender.org/developer/F8722108/uv_scale-0.png) Good Example - Mesh, Scale - X - 0 -- non neighboring: ![mesh_scale-0_non.png](https://archive.blender.org/developer/F8722110/mesh_scale-0_non.png) Good Example - UV, Scale - X - 0 -- non neighboring: ![uv_scale-0_non.png](https://archive.blender.org/developer/F8722113/uv_scale-0_non.png) **Exact steps for others to reproduce the error** [uv-indivorigin.blend](https://archive.blender.org/developer/F8722117/uv-indivorigin.blend) - Load attached .blend - Ensure pivots are set to Individual Origins - Try to align edges on X or Y axis in the UV editor for example
Author
Member
Added subscriber: @deadpin
Added subscriber: @mano-wii
This behavior was even worse. See #72325
The dedicated UV selection does not differentiate between the selection of edges and vertices.
But in this case it is using Mesh's selection system.
It should be supported, so..., confirming as a BUG.
This behavior was even worse. See #72325 The dedicated UV selection does not differentiate between the selection of edges and vertices. But in this case it is using Mesh's selection system. It should be supported, so..., confirming as a BUG.
Added subscriber: @ideasman42
Looked into this, current UV-island logic doesn't take edge selection into account,
and it doesn't look like a small change to support it.
I'd rather rewrite this to use bmesh-connectivity information which will make supporting this case quite simple.
Setting this as a TODO
Looked into this, current UV-island logic doesn't take edge selection into account, and it doesn't look like a small change to support it. I'd rather rewrite this to use bmesh-connectivity information which will make supporting this case quite simple. Setting this as a TODO
Campbell Barton changed title from UV: Pivot set to Individual Origins does not work in some instances to UV: Pivot set to Individual Origins does not work properly w/ sync-select & edge selection 2020-08-05 07:59:40 +02:00
Chris Blackbourn self-assigned this 2022-06-30 00:16:06 +02:00
This issue was referenced by 178868cf42
This issue was referenced by 178868cf42594bf7eedfa4db93ba8b7f3bf017ce
5 Participants
Reference: blender/blender#79304
