Incorrect volume calculation for complex object from 3D-Print toolbox #79394
Reference: blender/blender#79394
Operating system: macOS 10.14.6
Graphics card: Intel Iris Plus Graphics 655
Broken: 2.83.3
Worked: -
When using the 3D-Print toolbox (or any code using
bmesh.types.BMesh.calc_volume()
) to calculate the volume of a complex closed object I noticed that the volume calculation is incorrect if the object is moved far away from the 0,0,0 mark and becomes more incorrect the further the 3D object is displaced from the 0,0,0 origin.No problems if the object is a simple cube. This was readily reported (https://developer.blender.org/T73295) and marked as resolved, but the problem remains for complex objects.
*Add a Monkey head at the 0,0,0 mark in blender.
*Use 3D-Print toolbox to calculate volume, note that the volume is 2255372 cm cubed.
*Use transform location and move object 100m units in x, y & z directions.
*Re do volume calculation in 3D-Print toolbox, the volume should now say 5561196 cm cubed.
*Volume of the standard cube (8000000 cm3) is the same irrespective of the location (indeed fixing the issue raised in https://developer.blender.org/T73295).
Many thanks in advance.
Added subscriber: @alexis.maizel
Added subscriber: @rjg
This could potentially be fixed by
0ab66dd63f
if it has the same cause as #79369. I haven't had time to test this though.Added subscriber: @Foaly
Keep in mind that calculating the volume reliably can only work on manifold meshes.
The default Suzanne mesh is not manifold.
However, it would of course be better if it could compute a reasonable approximate volume even in the non-manifold case.
@Foaly: Thanks for the note. Indeed, "fixing" the Suzanne mesh to make it manifold does make the volume calculations invariant with regard to location. I guess this is not really a bug but a limitation.
Added subscriber: @iss
Following steps now this looks like it's resolved now, so will close regardless of being limitation.
