Motion Tracking: marker does not remember 'enabled' state #79453
5 Participants
Reference: blender/blender#79453
Operating system: Linux-5.7.10-201.fc32.x86_64-x86_64-with-fedora-32-Thirty_Two 64 Bits
Graphics card: GeForce GTX 970M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 440.100
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-08-03 12:21, hash:
92f6f6d30e
Worked: 63ee3db96107^
Caused by
63ee3db961
Steps to reproduce
State is not remembered [these are no real FCurve keyframes, but tracking dopesheet also does not add 'diamonds' -- but prior to
63ee3db961
tracking would remember this]. Instead marker is disabled for all time line.I've reset system to defaults (File->Defaults->Load Factory settings).
Thanks.
Added subscriber: @baeng72
Added subscriber: @bent
Added subscribers: @Sergey, @lichtwerk
Markers
enabled
state is not part of autokeying.Autokeying in general is only for Objects, Bones and Masks (see its tooltip).
In fact, I think there is not really a way to insert/remove keyframes for enabled by hand even (you cannot keyframe that property in the UI)?
It is exposed to RNA though as
but the UI is not displaying this directly (UI is using internal
template_marker
instead)But even doing it from python, something like
will fail because
MovieTrackingMarker
doesnt have a properRNA_def_struct_path_func
.So this really is not bug, just asking @Sergey here to check if implementing something like
rna_trackingMarker_path
would make sense [if that would work properly, we could at least use.keyframe_insert("mute")
from python properly]Changed status from 'Needs Triage' to: 'Archived'
Marker defines position starting at the frame the marker is added at, ending at the frame where another marker is inserted, You are adding a single marker, so the fact that it affects the entire timeline is expected.
This property can not be covered with keyframe-based animation, because it controls something which is already very similar to the animation system itself. It is also not enough to implement the
path
function for RNA as the solver is not using F-Curve based animation for anything other than weight.Generally, you shouldn't be using animation system to define what happens with the tracking data, but use tracker and some manual input to control what;s going on.
Thanks for the report, but it is not a bug.
@Sergey: thx pointing that out
Sigh, thanks for 'burying the lede'.
Did you even load some greenscreen footage into the VFX editor, add a few tracks, enable/disable them at various points and the scrub through the footage from start to finish to see if they 'remember' when they where enabled/disabled?
It works in previous versions, for example, 2.79, 2.80, 2.82, 2.82a. But not in 2.83.3
I'm fucking sorry I mentioned autokeying, I saw it in a tutorial for setting up a keying screen once, so do it automatically when setting up tracking markers.
This is fucking pathetic.
You have seen 'keyframe' and ignored the bug.
Changed status from 'Archived' to: 'Confirmed'
Please tone down, we are handling lots of reports and if the report is not straight to the point (or is about autokeying -- when in reality it is about something else), then it can happen that things go missing...
But I do see the issue now, will check on this...
After looking deeper into the issue, there is indeed a regression caused by
63ee3db961
.However, the feature you are describing has nothing to do with auto-keyframe. You don't need to have it enabled, is totally ignored for such kind of edits.
@JacquesLucke , will you have time to re-iterate over the initial bugfix?
P.S. This is why it is very important to follow bug report guidelines and fill in all requested information in the template.
Blender 2.83.3 doesn't auto keyframe tracksto Motion Tracking: marker does not remember 'enabled' state@JacquesLucke : I think I got it
This issue was referenced by
f921ae4665
