GL_BLEND ignores texture alpha channel #79491
6 Participants
Reference: blender/blender#79491
Graphics card: GeForce GTX 860M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 436.48
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-08-03 05:14, hash:
144f780c71
Worked: 2.83
Using
bgl.glEnable(bgl.GL_BLEND)
in 2.91 and 2.90 with image shader has no effect on alpha channel display.Exact steps for others to reproduce the error
gl_blend.blend
Added subscriber: @MikhailRachinskiy
Added subscriber: @lichtwerk
Confirmed, checking...
Added subscribers: @JacquesLucke, @ideasman42
This changed in
cfa788cf9a
.Seems like you need an additional call with something like
prior to calling your
I assume this is not a bug, but maybe @JacquesLucke or @ideasman42 have an opinion?
Thanks, it does fix the issue, but it violates OpenGL spec , where it says
glClearColor
has to be initialized with 0.And if it's not a bug, then it better be mentioned in Python API section of 2.90 release notes.
Added subscribers: @christian.rauch, @brecht, @EAW
Reading D7599: correctly draw UI with enabled alpha channel, it seems possible that
cfa788cf9a
was committed based upon a miscommunication/misunderstanding.So there was a bug with alpha handling
1: only in a specific version of a driver, and
2: only on a specific GPUs, while
3: only using a specific Windowing system (Wayland),
4: That had already been fixed upstream.
It was designed to be temporary until the fixed driver in Ubuntu 20.4.1 is released, which will be on August 6 2020.
It seems that @christian.rauch wanted to change the Blender UI handling of alpha to be initialized to 1.0f on Wayland, but instead that change was committed in a way that affects Blender on all systems. It wasn't
#ifdef
ed.@brecht did sign off on the "other clear color changes," but it isn't clear (pun unavoidable😉) whether he thought they were suppose to be only for Wayland or the entire code base.
I am curious as to how the rest of the window managers handle UI drawing since
glClearColor
initializing alpha to 0.0 has been in the code since before 2.5 (see line 213).I just realized your example @MikhailRachinskiy is from Blender's API documentation. https://docs.blender.org/api/master/gpu.html#generate-a-texture-using-offscreen-rendering
So if this change was intentional, that would need to be updated too.
If you call
glClear
withoutglClearColor
, that is a bug in the Python script. The Python API makes no guarantee that all OpenGL state is set to defaults when Python scripts are executed.This issue was referenced by
229fe01a15
Maybe I can clear up some misconceptions around the UI alpha channel to avoid confusion for future issues referring to this.
There are two dependant issues, which are reflected by the two commits in https://developer.blender.org/D7599:
There was a bug with the buffer format selection on Wayland for a specific Intel GPU driver (point 1). This is not related to the alpha channel (point 2). While the Wayland bugfix (1) would be obsolete for users of never
iris
drivers, the alpha channel bug (2) will be present for any system that enables the alpha channel in the OpenGL configuration.No, I wanted the alpha to be correctly initialised to 1.0 for all OpenGL configurations on EGL, GLX, WGL, CGL (point 2). An
#ifdef
just for Wayland does not make sense, since all other OpenGL configurations would still suffer from transparent UI elements with alpha channel.An old bug is still a bug :-) It may be that this issue did not show before, since you will only see transparent windows with more modern window compositors.
