Crash on loading blends with nested BG scenes
Graphics card: GeForce GTX 960/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 446.14
Broken: version: 2.83.1, branch: master, commit date: 2020-06-25 09:47, hash: rB8289fc688b3e
Blender crashes when a file that has linked BG scene that in turn has nested BG scene(s) Three levels of nested BG scenes seems to cause trouble.
1: make a blend (mine has some text at each step as reference), save.
2: link step 1's blend scene into a new blend and set as the BG scene, save.
3: link the blend from step 2's scene into a 3rd blend and set as the BG scene, save.
4: link the blend from step 3's scene into a 4rd blend and set as the BG scene, save.
5: try to load the saved blend from step 4.
Based on an issue we are having with our production files I tried to replicate an crash. I can't say I can reproduce it without fail but I have a series of nest BG scene blends that crash Blender. Up to the 3rd scene seems OK, but the 4th crashes. If I change the names and text the 4th seems OK, but won't save a new text object in the scene.
Exception thrown: read access violation. sce_iter was 0x20786D90C98.
>	blender.exe!scene_validate_setscene__liblink(Scene * sce, const int totscene) Line 6090	C
 	blender.exe!lib_link_scenes_check_set(Main * bmain) Line 6289	C
 	blender.exe!lib_link_all(FileData * fd, Main * bmain) Line 9711	C
 	blender.exe!read_libraries(FileData * basefd, ListBase * mainlist) Line 12119	C
 	blender.exe!blo_read_file_internal(FileData * fd, const unsigned char * filepath) Line 9948	C
 	blender.exe!BLO_read_from_file(const unsigned char * filepath, eBLOReadSkip skip_flags, ReportList * reports) Line 320	C
 	blender.exe!BKE_blendfile_read(bContext * C, const unsigned char * filepath, const BlendFileReadParams * params, ReportList * reports) Line 444	C
 	blender.exe!WM_file_read(bContext * C, const unsigned char * filepath, ReportList * reports) Line 712	C
 	blender.exe!wm_file_read_opwrap(bContext * C, const unsigned char * filepath, ReportList * reports, const bool autoexec_init) Line 2177	C
 	blender.exe!wm_open_mainfile__open(bContext * C, wmOperator * op) Line 2319	C
 	blender.exe!operator_state_dispatch(bContext * C, wmOperator * op, OperatorDispatchTarget * targets) Line 2213	C
 	blender.exe!wm_open_mainfile_dispatch(bContext * C, wmOperator * op) Line 2346	C
 	blender.exe!wm_open_mainfile_invoke(bContext * C, wmOperator * op, const wmEvent * UNUSED_event) Line 2351	C
 	blender.exe!wm_operator_invoke(bContext * C, wmOperatorType * ot, wmEvent * event, PointerRNA * properties, ReportList * reports, const bool poll_only, bool use_last_properties) Line 1284	C
 	blender.exe!wm_operator_call_internal(bContext * C, wmOperatorType * ot, PointerRNA * properties, ReportList * reports, const short context, const bool poll_only, wmEvent * event) Line 1532	C
 	blender.exe!WM_operator_name_call_ptr(bContext * C, wmOperatorType * ot, short context, PointerRNA * properties) Line 1547	C
 	blender.exe!WM_operator_name_call_with_properties(bContext * C, const unsigned char * opstring, short context, IDProperty * properties) Line 1567	C
 	blender.exe!wm_open_mainfile_after_dialog_callback(bContext * C, void * user_data) Line 2238	C
 	blender.exe!wm_block_file_close_discard(bContext * C, void * arg_block, void * arg_data) Line 3071	C
 	blender.exe!ui_apply_but_funcs_after(bContext * C) Line 922	C
 	blender.exe!ui_popup_handler(bContext * C, const wmEvent * event, void * userdata) Line 10889	C
 	blender.exe!wm_handler_ui_call(bContext * C, wmEventHandler_UI * handler, const wmEvent * event, int always_pass) Line 622	C
 	blender.exe!wm_handlers_do_intern(bContext * C, wmEvent * event, ListBase * handlers) Line 2743	C
 	blender.exe!wm_handlers_do(bContext * C, wmEvent * event, ListBase * handlers) Line 2854	C
 	blender.exe!wm_event_do_handlers(bContext * C) Line 3283	C
 	blender.exe!WM_main(bContext * C) Line 478	C
 	blender.exe!main(int argc, const unsigned char * * UNUSED_argv_c) Line 548	C
 	[External Code]
Richard Antalik (ISS) changed the task status from Needs Triage to Confirmed.Aug 6 2020, 7:03 AM
Yes, I am sorry about the file naming. I can replicate the crash by linking the linking_scene.blend's scene into a fresh blend and setting it to the background, saving and then attempting to open it. The linking_scene.blend itself opens fine.
