Enhance ways of accessing active modifier for poll functions of operators #79735
Reference: blender/blender#79735
Currently, poll function of operators can only get the modifier they are supposed to work on from the context. This is often missing (when called from shortcuts e.g., also with drag-n-drop of modifier panels...).
This is a sever problem for liboverrides, as some modifiers should then be edited (the locally added ones), and others not.
I can see two ways to solve that:
Added subscribers: @mont29, @brecht, @ideasman42
This is definitely an issue. It seems the operator system might need to be more flexible here. Two ideas:
Maybe these two ideas expand the scope of this task a bit, but together they would solve these sorts of situations.
Firstly, is there an example of what's currently not possible? (bug report for eg), even though the issue described makes sense, I'd like to have some steps that fail.
Since this can be solved using an active modifier, this is a more conservative choice, although I'd still like to look into the failing case in more detail.
Enhance ways to access to 'active' modifier for poll funtions of operators.to Enhance ways to access to 'active' modifier for poll functions of operators.@ideasman42 ah, thought the report that triggered that task would be more visible from this side... It was #79635 (Library overrides - modifiers).
In a nutshell, on liboverride objects, many modifier operators are only allowed on local (added to the override) modifiers, and not on the ones coming from the linked data. Thus the need to know on which modifier we are working on (we'd need the same for constraints btw, did not check yet whether those were always properly accessible from the
poll
functions of their operators either).So always having access to an active modifier would work for that specific case at least.
This is basically already implemented if I understand this idea correctly.
UI_region_panel_custom_data_under_cursor
is that lookup function. The problem is this is not accessible without the event (not in poll functions) so we need to store the active panel custom data somewhere. The invoke functions should probably be refactored to use that stored version instead of the lookup function then.@mont29 This image might make you happy:
{F9373310 size=full}
We're using an active modifier to set the node editor context for geometry nodes. Then the modifier shortcuts only affect the active modifier.
Enhance ways to access to 'active' modifier for poll functions of operators.to Enhance ways of accessing active modifier for poll functions of operators
