After swapping the basis shape key to another one, the former basis key still affects the new one #79892
8 Participants
Reference: blender/blender#79892
2.91.0
What I try to do: I would like to make a later created shape key the basis one.
I can do it with moving it to the top, and setting the former basis key's "Relative To" setting to this new basis one.
It works as expected until I'd like to make further changes in the old basis key (now just a regular shape key)
It affects the current basis, where - by definition - there's no "relative to" setting, so it shouldn't be affected by anything.
I noticed that it does work as expected if I'm using the "shape key in edit mode" option - BUT it only behaves well until I come back to object mode. Then the new basis key instantaneously gets all the modifications I just made on the old basis.
The steps are below on an image with descriptions, but I attached the blend file too. Just change the shape key called "starting basis" and check what happens with the real basis one.
shapekey_error.blend
Note: there was one time when I created a shape key pair where this whole thing worked as intended. But out of (literally) 6 tries, only one worked and I couldn't pinpoint what I did differently in that case.
Added subscriber: @DavidKozma
#81644 was marked as duplicate of this issue
Added subscribers: @mano-wii, @ideasman42, @iss
I can reproduce this, but I am not sure if this is a bug. @mano-wii or @ideasman42, do you know?
I'm not sure, either.
Bmesh updates/edits shape keys when exiting edit mode.
It is quite possible that it is updating the wrong shapekey.
So I risk confirming it as a bug for now. Further investigation is needed.
Added subscriber: @3dpprofessor
Is this the same problem I found?
https://youtu.be/xSGake54S-8
If it's not a bug, it's at least inconstant behavior. I'd like to be able to animate the duplicates independently.
Not sure if that is bug, but it is definitely unrelated to this report.
Duplicating object should duplicate it's data unless you choose to not do it. with own data what you posted shouldn't happen
Added subscriber: @lukostello
Added subscriber: @Mysteryem-2
What happens with this setup is that the first shape key ends up relative to the second shape key, which happens to be relative to the first shape key. Editing either shape key will affect the other which is the behaviour I expect when two shape keys are relative to one another.
If, before step 3, in this example, you change "wannabe basis" so that it's relative to itself instead of "starting basis". When editing "starting basis" in step 5, it will no longer also affect "wannabe basis" because we made sure that "wannabe basis" was relative to itself instead of "starting basis".
The main issue here in my opinion is that Blender hides the key that the first shape key is relative to from the UI, despite the fact that it still has an effect as seen here, which can lead to confusing situations.
I think that either the first shape key should always be forced to be relative to itself, always act like it's relative to itself or its relative key should be made visible and modifiable in the UI.
The latter is probably the easiest and simplest since it doesn't change any existing behaviour and only requires a modification of the UI file properties_data_mesh.py.
Added subscriber: @AdamJanz
Added subscriber: @rwman
